td panno
4 spot brakes
painted
shocks
present
TD Panno
Well my poor panno has sat for many years (almost 5) but its finally getting some much needed work. Since the last pic all underneath has been stripped and por15ed as well as the engine bay and inner guards. Decided to wack a turbo motor together that i had all the parts for, almost finished building it just missing a few bits namely a turbo and clutch....
With much thanks to knobby for having an awesome shed
motor is a mystery balanced newish g180 with my monster port head and cdt turbo gear
Current Fleet
G200w itb TD panelvan project (13yrs now)
Previous Gems
CDT S3 turbo and twin tc coupe, XSN20 draw thru nitrous late model coupe, G180w TD Panno, Te sedan piazza/g180 then blow thru g180, Draw Thru TC Sedan, Twin Weber g180 Wagon
Previous Gems
Re: TD Panno
With any luck my panno will finally be in the same location as myself again for some much needed work and to meet its new g200w powerplant. Will hopefully have the itbs in my possession soon also so i can set teh master cylinder up.
- Attachments
- 10959767_10153113153803594_8786395734307250121_n.jpg (162.51 KiB) Viewed 12049 times
Current Fleet
Previous Gems
Previous Gems
Re: TD Panno
Since some other projects are being resurrected might as well add some new pics. Nothing happens fast with the panno but have recently installed my zzr diff, painted my floors, mounted some braided lines and some other odds and ends
Current Fleet
Previous Gems
Previous Gems
Re: TD Panno
Also chasing someone to add a rear diagonal to the cage if anyone knows anyone that can do that sort of thing
Current Fleet
Previous Gems
Previous Gems
Re: TD Panno
Good to see something going on with it!
Should get on the QLD Geminats train and get it done for it.
Re: TD Panno
What are the throttle bodies off?
Re: TD Panno
45mm efi hardware, i think ill need longer stacks though
Current Fleet
Previous Gems
Previous Gems
Re: TD Panno
No pics but for the first time in about 13 years the engine bay is connected to the rear wheels!
slowly chipping away also the braided lines are all run and connected now for brakes.
Current Fleet
Previous Gems
Previous Gems
