350 chev gemini coupe
kartracer1841
Post by kartracer1841 »
WOPISH wrote:Don't try and finish it by tomorrow, take your time, there are always going to be all types of events available.
Maybe reach out to fellow Radelaideians to give you a hand.....
Don't give up mate, i have a couple of times and i have regretted it heaps.
i am not giving up on the car just on this site i am sick of reading all of the s*#t on here and people not getting alone. this car will be finished even if it takes me 10 years
kartracer1841
this is what 5000 dollars gets you and a trip to victorica for 2 weeks not very much if you ask me most off this stuff is brand new apart from the dizzy that is 2 hours old.
brand new collara rods mind the spelling
injection setup
more pictures to come still have heaps more to upload
kartracer1841
here are some more pictures should be picking up the pistons and a few more thing then i need to wait for my bank account to reapair for a while.
here are the pictures
http://img233.imageshack.us/g/163492187 ... 07510.jpg/
i also have a new brake kit coming soon from hoppers. then i am saving up for a full roll cage got quote 6000 so that it that me a while to save up for. but i have heaps of little things that dont cost much to do 1st.
kartracer1841
after 1000 welding burns the welding is done. well my part anyway. got some pistons for the motor and a gear drive for the front and a timing cover. now i am putting the front end back it and then on to the diff then it is going to my dads work to sit there until i strip my other white gemini. as my parents said one gemini only so the white one is getting parted out and all the good bits are going into this one and the rest is getting sold including the motor.
here are some of the pictures.
http://img35.imageshack.us/g/1690331950 ... 49310.jpg/
http://img20.imageshack.us/g/1681041950 ... 96310.jpg/
kartracer1841
update got my brakes one side is bolted on. my heads i got for this motor have hair line cracks in them so they are are bin job. so i might just get some iron heads as for burnouts they are better as the head disapaces slowy and less likey to crack them and they are cheaper so the one i will save i will just spend it on porting. but if i get iron heads i have to run pump fuel so i will lose about 80hp so i will only have round 520hp but that should be heaps for a burnout car. and i also will save money on all of the fuel system as it is just pump fuel.
some pictures of the brakes some of the little things i am not happy with like the grease cap will only go on 3/4 on the way so i will just have to trim that down abit. also got some pictures of my motor gear drive cover and a motor front support bracket
here they are
http://img20.imageshack.us/g/1689821980 ... 70610.jpg/
kartracer1841
todays update
the front brakes are on both sides same with the steering stops and i welding on the brake line brackets i have started making the pedal up. pictures will come soon but i am very happy with the way the car has been taking shape. just having abit of lunch then i am going out again as i want to finish the pedal today then i just need to mount the master cylinder when i get it.
kartracer1841
big things has been happing to the front brakes the motor and the diff. there will be running a 28 spline diff in a Gemini diff center. my mate who works in a diff shop thinks this will be good for 700hp and it will only cost a few hundred to make and fit. and got a stock bore 350 chev block and a full maunal t400 gearbox coming from the states and got a high engery 350 sump for it to. also made up a spacer for the booster less brake master set up just need to get it laser cut now. then bolt it in.
there will be no more pictures due to i have a big sponsor helping me out n they said keep it under raps so this will be the last update until the car is done in a few years time
headstrong
Location: putting my pets on facebook because i cbf paying them attention unless its online...
Post by headstrong »
kartracer1841 wrote:big things has been happing to the front brakes the motor and the diff. there will be running a 28 spline diff in a Gemini diff center. my mate who works in a diff shop thinks this will be good for 700hp and it will only cost a few hundred to make and fit. and got a stock bore 350 chev block and a full maunal t400 gearbox coming from the states and got a high engery 350 sump for it to. also made up a spacer for the booster less brake master set up just need to get it laser cut now. then bolt it in.
f*#cking LOL you get sponsored by the adelaide gaslog fire specialist to put a fireplace in the boot? gaslog fire would be heaps easier than putting a wood fire in cos you would have to carry around to much weight with all that extre firewood
Scroll down for the meaning of life.
kartracer1841
update time motor is bolt in. just need to remove it to put some more braces in for them. it is soild mounted as the rubber mounts will just rip out. i have so many pictures but i will update when i have time. also i brought another 350 motor complete just to rebuild and put a cam in it and put my injection on and i will just it until i set up the other motor i will be using. thanks
kartracer1841
here is some pictures
http://img832.imageshack.us/g/226122220 ... 57510.jpg/
a picture of the gemini 28 spline diff centre i made on the mill and lathe at home.
enjoy
kartracer1841
update time
dont really have time to do much due to work.
i purchased a few more parts i need and i finshed off the engine mounts so they are all finished. i am going to be picking up my other motor in the next few weeks and fitting the hang on parts and putting that in with the exhaust on. so when that is all donei will cut the floor and the trans tunnel from the hz stateman i have brought for parts and welding that in. after that i will get on to the diff and then the tailshaft. i will be using a 4wd tailshaft as my t400 doesnt have a slip yoke.it is soild as it ws from a pick up form the states and they are meant to be heaps stronger. i also had to drop the rack down and gind the logos off so it clears the sump as the logos where just touching the sump.
pictures of the mounts and some off my parts an the mod to the rack so it clears the sump
http://img215.imageshack.us/g/225566226 ... 94610.jpg/
kartracer1841
i little sneak pic of my motor. hope you enjoy
this is my dummy motor but i will be rebuilding this one and using it
kartracer1841
over the past few months i havent really worked on it much due to alot of other things. but i got back to it this weekend. the front half of the trans tunnel is welded inside and out i uses 1.4 sheet mental to do it. i have started to do the back half that should be done with in a day. i have also started to mod my rack but i havent got and pictures of that.
pictures
ImageShack Album - 8 images
kartracer1841
i have done alot this weekend as i had abit of spare time on my hands. the trans tunnel is finished it looks very nice. well i think so anyway. i also dummy fitted the motor again to make sure nothing else what hitting that i forgot about about. nothing was so it looks like i can start on the backend of the car and fit the tailshaft loop. i also what to make the rear end of the car near the shockers abit stronger as that looks to be a weak spot but that shouldnt be to hard. the motor has been out about 20 times to make it fit nice and neat so i am glad that it fits nice that way i want it too. i also have purchashed a few more parts for the car for the fuel system as soon as they arrive i will get some pictures up. after sitting back and looking over the car the only part that hasnt been changed and is close to standard is the doors and the boot lid but they have be shaved to.
here is some pictures of the weekends work
http://imageshack.us/g/220/19082011562.jpg/
kartracer1841
update time. i havent really done much as i am waiting on alot of parts from the states but i have stripped my sump and the nos bottle ready to get painted. i have also stripped the diff down and put new bearings on the pinion shaft and put that back in but i am waiting on the bearings for my diff centre and a pinion seal. once i have that i can put the centre in a put the diff hat back on and get my axles made up to suit. also i have a picture of the rear suppport for the shockers and it will also make fitting my boot set up easier. i also cleaned the oil galleys and the water ports with a die grinder on both of my heads up so they can get sent away and rebuilt very soon.
here are some pictures
http://imageshack.us/g/706/01102011611.jpg/
