I more meant ditch wold buy haltech. And this doesn't sound too good^moley wrote:Wolf only using it as I bought it off the guy who blew up my legacy for 200 dollars with the msd
The 10 year coupe build Tas
Re: The 10 year coupe build Tas
haha yea no it wasn't the ecu, he wound up the boost (was already running 19psi) he put 91 in it and drove the piss out of it up a hill with the stereo up flat out and didn't hear it pingin until it split the bore, absolute moron then proceeded to tell people that I didn't build the engine properly had to have words with him
Good work f*$kwit!
*shakes head.
Makes you wonder about some c*#nts.
*shakes head.
Right the whole cars in putty, the bumpers, boot and bonnet have been blasted internally and are in primer and putty the bumpers have been blasted and primed. Hooked up the fuel lines, modified the fuel pump housing to 8mm and the tank return. Put the hi volume lift pump in the tank, cleaned the sender, painted the tank, fitted up the fuel cap. speed filed back the putty, needs a little bot more here and there. Made the other seat brace, started the marine carpet the boot, bought a new 044, New surge tank, pump holder, New gear knob, pedals and some plush carpet, bought the roof lining gear, the head has been ported, o/s stainless valves, New retainers, custom double springs, custom big turbo cam, 1000cc injectors turned up, have the rods ordered for the New block, pistons ready to bore, sump is made and leak tested, bought the ceramic puck clutch, swivel feet, mls gasket from Lee, have completely 2 pak recoated the whole interior of the car in chip guard deadner shite thick as. After finding more pin holes that I had to weld up. Bought lowered pan hard Rod, made wheel spacers for the 17s put longer studs in, bought New slotter rotors, put on the xb master and had a prick of a time bleeding with all the New lines. Now has brakes, customised the dash panel and put the boost and oil pressure in the tg dash panel, puttyd that. Re ran battery cables and fuel pump wiring can't think what else I'm a bit light headed from sniffing quick grip
Right after everyone talking about doing ttheir boots out I have made up a carpet setup, will post pics when I can. Have the amp and wiring in, put in the bits and pieces and Bluetooth Mike for the New stereo. Car has been blocked back and has been repaired where necessary as the panel beater wasn't Happy. Have the surge tank, pump and filter holder etc now so il put all that stuff in hopefully tomorrow night. Put the accel cable and associated in. New plenum chamber and fuel rail is getting made, ic pipes are made but the cold side will need to be jigged as the plenum will be front entry. Got the door handles powder coated, getting the light surrounds powder coated
Pics man wtf!?!?!
Hey will post pics soon haven't had time to take any!
Will take some pics in the morning did a fair bit more but I can't get any pics because it's too dark. Hooked up the fuel setup, tidyd all the wiring, repaired the broken wires setup an earth Point in the boot. Turned on my stereo which hasn't been on for years and it had rage against the machine in it. Like going back in time
Haha brilliant!
Sorry I haven't been home during the daylight hours much
There is a custom inlet manifold in the wind too designs being thrown around atm
