The 10 year coupe build Tas
Re: The 10 year coupe build Tas
I honestly cant remember its been about 6 years since i did it. I know it would have been the last of the injected 4 cyls. Ts i think 2.6? Just machined the inside down from memory and put a roll pin through it and the gemi shaft.
I will tidy up the engine bay on the weekend it will all be together when my blower pulley shows up the spastics sent a 308 one
Gilmer pulley on blower had to flip it and machine it. Now just have a lot of reassembly wiring and fabbing to do hopefully i can start it over Christmas
Car is running. Sounds off its face. Need to do a few things but im happy now to change the turbo and throw in the new motor when i finally get some rods
Btw car makes 15 psi just revving it with no load. Just about to order the rods. Ordering a td05 20g 8cm its looking like the biggest i will get in there should still be good for decent power with great response tried to email the video to johno but it says the file is too large will try and compress
Im thinking if i weld a reducer on the front of the td06 housing i will be able to get a td06 sl2 in there. Might have to take the punt and order one. Im getting a bit toey waiting for these rods
I completely missed this bit! Sounds pretty sweet man. Still twin charging?
Did you send pics through?
Yea i sent them through. Cant you hear the blower haha
Should update this old sport
I would but I can post any effin pictures
Yeah so I have painted the engine bay
Put most of the lines back
Put the hubs and the brakes on the front
Assembled the diff and set it up fyi you need to machine your pinion with altra 9 centre as it hits!
The centre didn't turn up on time so there has been a snowball effect and the diff is only out getting the axles done now so I have missed my window to get it painted for another few weeks now
Thanks to Nick for getting the hubs to me on time
I will hopefully pick up the diff today and put it together and get it rolling.
Wouldn't have been so bad if I hadn't of sold all the stuff that was on the car!
Movement man. This is f*#cking sick!
#Yellowcoupenats2018
cept urs will a little faster and a lot more refreshing to look at
#stilllotsofshittodobutimfknsmashingit
- Attachments
- IMG_20170721_184555_01.jpg (400.45 KiB) Viewed 6435 times
- IMG_20170721_184558_01.jpg (455.55 KiB) Viewed 6435 times
