The 10 year coupe build Tas
DR_GEM
Re: The 10 year coupe build Tas
Post by DR_GEM »
Twin charging isn't what it's cracked out to be. If you want great response and top end power, a properly sorted twin scroll turbo setup will deliver without the niggles of a twin charged system.
In my humble opinion only
moley
Post by moley »
Have you ever been in one?
Ians has 9psi at idle, 35psi top end
I know everyone says they are inefficient blah blah but the response down low is streets away from a turbo
According to the ass dyno only :D
I got the numbers bro.
It's literally 10mm longer. If you've ever seen a piazza one? It's the same.
Sorry about the delay.
moley
Post by moley »
Thanks mate legend!
moley
Post by moley »
Gemini just pulled 279.5kw atw on a run in tune, wastegate pressure but is creeping, no timing in it either.
This thing sounds absolutely nuts and is going to kill me
moley wrote:Gemini just pulled 279.5kw atw on a run in tune, wastegate pressure but is creeping, no timing in it either.
f*#k yes. Wheres the vid?! And what spring have you got in it, 15psi?
The film quality is crap man you wouldn't want to see it
*chuckles pompously
moley
Post by moley »
14psi spring E85, 287atw this morning on a fresh run.
It's going about 18psi ish.
I pulled the rocker cover tonight and did the clearances and put a new filler on it because it wouldnt stop leaking.
Will put it back in tomorrow night, change the oil and feed her again.
I don't think the clutch is going to handle it though, we were getting some slip above 250kw
CLUTCH LOLOLOL Ohh man no way.
That's enough to drive it on and off the boat man.
It's time.
Make the call :D
moley
Post by moley »
Trying to get the fker painted!
DR_GEM
Post by DR_GEM »
Awesome news! Great result. You did best me to it it you prick lol
18psi isn't even waking that turbo up yet.
Pump 30psi through it then you're gonna s*#t your pants :)
moley
Post by moley »
Thanks Mick
I'm already s!*tting my pants, we had to strap it down that tight because it was spinning the wheels on the dyno. So it's gonna be terrible to drive on the road..
moley
Post by moley »
At the body works. It was gonna be back Saturday but it's sounding like it ain't gonna happen. I can't push them they are doing it for next to nothing
moley
Post by moley »
Started sorting all the s*#t ready to go back on the car.
I reckon as soon as I get it back there's gonna be some all nighters getting g it finished.
Need it drive able by the 14th otherwise I won't get it engineered
DR_GEM
Post by DR_GEM »
Good luck man
