GEM77A Reincarnate - The Gem Reaper
Re: GEM77A Reincarnate - The Gem Reaper
Nice coming along well.
firebug
Post by firebug »
Some great progress there. AC lines look very neat!
gemsince88
Post by gemsince88 »
Merry Christmas and a happy new year!
AC hard lines are done!
ImageDSC_0098 (Medium) by Justin Sherwood, on Flickr
Carpet is in!
ImageDSC_0099 (Medium) by Justin Sherwood, on Flickr
Finished stripping the wreck and now you can see that not one part of this was left straight!
ImageDSC_0087 (Medium) by Justin Sherwood, on Flickr
ImageDSC_0088 (Medium) by Justin Sherwood, on Flickr
ImageDSC_0089 (Medium) by Justin Sherwood, on Flickr
ImageDSC_0090 (Medium) by Justin Sherwood, on Flickr
ImageDSC_0091 (Medium) by Justin Sherwood, on Flickr
Then it met this!
ImageDSC_0092 (Medium) by Justin Sherwood, on Flickr
ImageDSC_0093 (Medium) by Justin Sherwood, on Flickr
I kept the floor pan and box sections near the front screen for rust repair panels.
ImageDSC_0094 (Medium) by Justin Sherwood, on Flickr
Then the rest went in the trailer to the tip.
ImageDSC_0095 (Medium) by Justin Sherwood, on Flickr
ImageDSC_0096 (Medium) by Justin Sherwood, on Flickr
And what I think of the whole re-body a car idea! :evil:
ImageDSC_0097 (Medium) by Justin Sherwood, on Flickr
I still get angry when I think about all my hard work thrown against a rock due to carelessness. Now there is one less reminder!
it'll be worth it when it's all finished man.
gemsince88
Jonno wrote:it'll be worth it when it's all finished man.
Thanks Jonno! It will be better than before.
gemsince88
I was never happy with how I had the radiator overflow bottle so something else had to be done. I had heard of Darren and others using the washer bottle as an overflow bottle but I still would like to use the windscreen washers. I found an overflow bottle on Fleebay that fits the washer bottle mount. It came with a mount so this will be used to relocate the washer bottle.
Image20031686_1835152093161679_7005835309625692479_n by Justin Sherwood, on Flickr
Kristy had a whole bunch of her family up this weekend so I ran away to work to make some things up.
First thing to sort was a compressor bracket. Arie had a few Rodeo kits but they have the compressor on the wrong side of the engine. Good for a last resort. So I got a bracket off Elky but it lacked strength, had a stupid way of tensioning the belt and had been f*#cked with.
Image20155623_1835152379828317_2459496464737011043_n by Justin Sherwood, on Flickr
So I ratted around the workshop and found another bracket that fits the compressor. I cut the mounts off the elky bracket and the "found" one (it had 1584cc Rodeo on the box but there is no way it would fit). Found a tensioner. Put it all together and tacked it up.
Image19990420_1835152326494989_1816364199483349997_n by Justin Sherwood, on Flickr
Test fitted or should I say put it next to the block and went "thats close enough".
Welded it all together and painted.
Made up a bracket to mount the washer bottle near the wiper motor.
Image19989719_1835152263161662_1531184344120524522_n by Justin Sherwood, on Flickr
Also made an idle up for the carb. I have no idea if it will work though.
Image20046588_1835152203161668_6016061107118550413_n by Justin Sherwood, on Flickr
Went to fit the compressor bracket and found that the dickhead who designed the bracket didn't take the oil filter into consideration so I had to get a smaller filter. Fitted the bracket and compressor then found that the crank pulley didn't line up. When I made the bracket I made it to line up with whatever lined up with the elky bracket which didn't line up with the pulley I had on there.
Luckily I had this. It's off a G200 Rodeo with power steering, I think!
Image19990600_1835152116495010_7908369797628797179_n by Justin Sherwood, on Flickr
Compared to the original pulley setup.
Image19989773_1835152163161672_4426937159551671104_n by Justin Sherwood, on Flickr
I originally bought it to put power steering on a gem (never going to happen) but lines up perfect with the compressor.
Changed the engine pulley and found a belt.
Image15966274_1564098596933698_8489271812068545932_n by Justin Sherwood, on Flickr
Went to fix a leak on the exhaust flange by tightening it up a bit but found the thread in the manifold is stripped. s*#t!
gemsince88
Did absolutely nothing to the car on the weekend due to family commitments ie changing the split air con system on the roof (3 stories up mind you) of my parents place but I did fix the exhaust this arvo.
Luckily a 10*1.25 tap fitted nicely in the stripped out flange stud hole so I tapped the new thread in and again grabbed some thread adapters with an 8mm stud from work. The original stud is some imperial thread, I think, don't care! Put the new stud in with a thread adapter, new nut and Bob's my uncle. Actually he's not, he's Kristys dad.
gemsince88
So 2 days of fiddle farting about some small progress was made. Matt finished putting the seat belts back in and put the door sill trims on. Trying to remember how I wired this thing 4 years ago was a major headfuck! While I was trying to remember how the dash wiring went Matt did a job I was dreading. He stripped straight seat back frames from the front seats that were in this body. Then carefully pulled the bent frames out of the sienna coloured seats and swapped them over. Popped 2 stitches start to finish. I was impressed while still trying to figure out wiring and put the dash in.
Image19989649_1835151976495024_3318977402906596029_n by Justin Sherwood, on Flickr
Image20031574_1835151886495033_3260873183633322821_n by Justin Sherwood, on Flickr
Image19990113_1835151729828382_3626440638266019531_n by Justin Sherwood, on Flickr
The bent drivers seat frame.
Image20046464_1835151779828377_2377219738088499311_n by Justin Sherwood, on Flickr
Finally got the dash in and fitted the front seats. The bases needed a little tweeking but eventually went in.
Bolted 3 of the 4 jellybean rims on.
Image19961215_1835151563161732_8902522798947208805_n by Justin Sherwood, on Flickr
Image19961277_1835149603161928_2962134811209963539_n by Justin Sherwood, on Flickr
Refitted the stereo that came with this body as the Blaupunkt unit is now in the Barina. Its a Pioneer cd/tuner with stacker capability. As a bonus I have a Pioneer stacker to go with it. It was a freebie that I picked up but can't remember where from. Think a mate of mine gave it to me out of a car he stripped for a demo derby. I know its old school these days but beggers can't be choosers!
While I was buggering around fitting the head unit I jammed up the top vent slide control and in the process of un jamming it I broke this bit.
Image20046864_1835151133161775_4291443929179907420_n by Justin Sherwood, on Flickr
Not a problem I thought as I have spares. After I pulled every box of spares out and spread them all over the garage I found one.
Image19895044_1835150449828510_6680860140013302431_n by Justin Sherwood, on Flickr
Image20139629_1835150976495124_86005305412899315_n by Justin Sherwood, on Flickr
Found a few other goodies I needed along the way.
Battery tray and clamp.
Image20106519_1835150076495214_3434419703677718232_n by Justin Sherwood, on Flickr
Tail lights and surrounds.
Image20032076_1835150176495204_5913457711206835409_n by Justin Sherwood, on Flickr
Finished putting the dash back together then drilled new holes for the jesus handles and screwed them on.
Image20106466_1835149779828577_54387331007743029_n by Justin Sherwood, on Flickr
Going to do something different for the centre console where the shifter used to be. Going to modify this to make a coin tray type thing. I think its a blend door from an E series Ford heater box.
Image19989606_1835150856495136_2151417367647059151_n by Justin Sherwood, on Flickr
Then finally it came out of the shed and we went for a test drive around the block.
Image20108118_1835149926495229_8427780863134320316_n by Justin Sherwood, on Flickr
Amazingly everything worked.
gemsince88
Matt decided to do a bit more and so removed the door cards, handles, lock barrel and mirror mount from the white doors. The plan is to just rub the outside back a bit on the 3 straight doors and give them a fresh coat of paint. The drivers door is a different story and I'll get to that later.
Then he stripped all the paint off the boot lid.
Image20106784_1835149483161940_7787086108086306353_n by Justin Sherwood, on Flickr
There's a few small dents and rust pits but pretty good.
I finished it off for the time being with some etch primer.
Getting there man!
gemsince88
I couldn't sleep so I thought I would do an update. It's been a while but I have been doing a little. There were a couple of weekends there that were stupidly hot so all I did was sit inside the house.
I scrounged through all my Kadett headlight bits and put together a pair of RHD H4 headlights. Even found a couple of working lamps to go with them. Did the same modifications to them as before to clear the battery and expansion tank then installed them. Fitted up the spot lights as well.
ImageDSC_0102 (Medium) by Justin Sherwood, on Flickr
Made up a few small wiring harnesses for the new bits in the engine bay. One to run the fans and compressor, one to extend the washer bottle power and one to finally finish powering up the ammeter and clock in the centre console.
ImageDSC_0103 (Medium) by Justin Sherwood, on Flickr
ImageDSC_0108 (Medium) by Justin Sherwood, on Flickr
Put it all in and immediately blew a fuse. Found that the dickhead who wired the relays got the coils and switch contacts arse about. Fixed that little problem and everything works.
Next I tackled the bent drivers door. Most of the outside skin was straight except for a nice 30 degree bend at the bottom right in the middle. The inside was another story! Most of it was caved in a good 50mm to the point you couldn't wind the window down. So after screws, wood, a FBH, kicking, standing on and a lot of swearing it is now as straight as it's going to be. It will still need copious amounts of bog on the lower panel inside as it now looks like one of the shooting range ducks you see at the show. I once blew the head off one of those ducks and the f#*ker stayed up! Oh well s*#t happens!
This is after pissing about getting the bend out of the bottom.
ImageDSC_0104 (Medium) by Justin Sherwood, on Flickr
ImageDSC_0105 (Medium) by Justin Sherwood, on Flickr
The guards were the next mission. The passenger side is off the wreck. It had a lovely twist to it but as it is rust free I thought it worth trying to save not to mention the more off the old car the more it means, if you're in to that.
The drivers side is one that was originally intended for the first car. I had a patch panel fitted to the bottom all those years ago so again rust free. Just needs a bit of work.
So after more beating, pushing and pulling the passenger guard is close. Test fitted the drivers door and guards. Not a bad fit considering!
Filled the dents and hollows in both guards as best I could and started bogging the inside of the drivers door. I am not showing you that bit as it is ugly! Got a coat of primer on them but they still need work.
Filled the 2 dents in the boot lid then primer.
ImageDSC_0111 (Medium) by Justin Sherwood, on Flickr
It is getting closer to being done!
f*#k yeah man! Not long now.
Under 2 months till Geminats. You gunna make it? Should almost walk through rego.
gemsince88
That's the plan!
gemsince88 wrote:That's the plan!
Mad camera will get a work out that weekend lol
gemsince88
The guards got a layer of spray putty.
ImageDSC_0114 (Medium) by Justin Sherwood, on Flickr
ImageDSC_0115 (Medium) by Justin Sherwood, on Flickr
While the guards were drying I made up a new tail pipe. The original one was mangled in the accident and this body didn't have one when I bought it. Also the one on the coupe was pretty ratshit so I had nothing that would go straight on. So I ripped tailpipe/hotdog off the coupe, had the remains of the original and a chrome chair strut body from work.
ImageDSC_0116 (Medium) by Justin Sherwood, on Flickr
ImageDSC_0117 (Medium) by Justin Sherwood, on Flickr
I cut the bend and bracket off the hotdog muffler then welded all three pieces together. Gave it a paint to help hide my dodgy welds and fitted it.
ImageDSC_0118 (Medium) by Justin Sherwood, on Flickr
ImageDSC_0119 (Medium) by Justin Sherwood, on Flickr
ImageDSC_0120 (Medium) by Justin Sherwood, on Flickr
Next I filled the bottom section inside the drivers door with bog and sanded back. There is approx 1kg of bog in this bit. I did say it was ugly!
ImageDSC_0121 (Medium) by Justin Sherwood, on Flickr
Sanded the guards back and sealed with primer. The drivers side is just about right and I almost got away with one layer of spray putty on the passenger side. It should be right with one more layer.
ImageDSC_0122 (Medium) by Justin Sherwood, on Flickr
ImageDSC_0123 (Medium) by Justin Sherwood, on Flickr
Sanded the small sections of bog in the drivers door and sealed with primer. It will need a little spray putty to smooth it out properly.
ImageDSC_0125 (Medium) by Justin Sherwood, on Flickr
Painted the tail light surrounds and centre garnish. The colour is simply a metallic black this time but the badge is the original with the greeny black still on it. I left it as a reminder of the original car plus more to the point I couldn't be f*#cked redoing it. The badge, even though bears some scars from the accident is still in better condition than the one that came with this car.
ImageDSC_0126 (Medium) by Justin Sherwood, on Flickr
Painted the grille. I am not happy with it so it still needs a bit of work.
ImageDSC_0127 (Medium) by Justin Sherwood, on Flickr
You may have noticed masking tape on the grille? That's because I'm doing something different this time, well sort of. I have done it before to a different car but I'm still not sure if it will have the effect I'm after. We will see!
