GEM77A Reincarnate - The Gem Reaper
- gemsince88
A few of you may have seen this effort recently.
488063_497394783604090_560214340_n by Justin Sherwood, on Flickr
481031_497394703604098_1599135485_n by Justin Sherwood, on Flickr
As a result I bought this from Brisbane.
545383_503209319689303_510577974_n by Justin Sherwood, on Flickr
404338_503209659689269_962882803_n by Justin Sherwood, on Flickr
Its a 2/77 TC that was originally auto.
f*#cking Persian Sand! I hate this colour! I can't get away from it.
There's a little bit of bog and a little bit of rust but generally straight.
The 5 speed conversion is a bit ordinary and the gearbox is crunchy.
408764_503209976355904_1908731148_n by Justin Sherwood, on Flickr
Note the TX style dash. It has the TX style heater too.
What everyone wants on their Gemini, a weber and extractors.
418089_503210326355869_563107084_n by Justin Sherwood, on Flickr
Here's the plan!
This thing is going to be stripped to a rolling shell. Ill fix what needs to be fixed and paint it the same Cotillion white and black as the old one.
The complete driveline will be swapped along with the whole interior. Even parts of the suspension from the wreck. It will have the original springs and the RTS lower control arms as before. Little things like the rear number plate braket and heater box will be changed to the later style as well.
When all is done there will be a small twist, if I can pull it off, just to make it different.
Here's the plan!
- gemsince88
A friend of mine came up from Melbourne on the weekend with his TC coupe to change his car back to manual. Only thing is we needed the flywheel and clutch out of this so the engine and box came out.
582490_540283555981879_1299532817_n by Justin Sherwood, on Flickr
If we hadn't decided to convert his car then I would still be procrastinating about pulling it apart. I'm only just starting to get back into it after having all my previous work thrown against a wall.
I sold the engine too so I didn't have to find a home for it and my mate took the extractors. I have too much s*#t as it is.
I found out too why the gearbox was crunchy. When we drained it there was about 200ml of oil in it. So there you go you can drive 700km in a Gemini with no oil in the gearbox!
- gemsince88
- gemsince88
Re: GEM77A/2 - The Gem Reaper
That's nice! All my photos have disappeared. f*#cking imageshack!
Well after running away from home with a lovely girl, having her ex chase us all over the countryside and conspire to kill me I am still here! Now I am settled in to a new home, with my girl and a new son, I have finally had a bit of time to work on this. It's not much but it's better than nothing.
Pulled the guards off expecting to find rust in the sill but one side is completely clean with the other having a 30mm diameter hole in it so not so bad. One of the guards though has about 20mm of bog all over it so it can go in the bin I think. Engine bay is just about stripped, dash is out and screens are out. Pulled the lower control arms out for some reason and found a lovely mismatched pair of cut springs off god only knows what. Another bin job!
DSC_0641 (Medium) by Justin Sherwood, on Flickr
DSC_0639 (Medium) by Justin Sherwood, on Flickr
Next is to complete pulling the interior out. Lets see how many years that takes me.
Am i seeing things or do you have two Persian Sand TX's? lol
- gemsince88
Nah you're not seeing things. This colour haunts me as my first Gem was this colour. I hated it then and still do which why this car is going white and the coupe is going green along with its Kadett C2 front.
Hooray for movement on this
Wow you have been busy . Welcome back . Dont strip it completely . Just do what NEEDS to be done ...
- gemsince88
Re: GEM77A Reincarnate - The Gem Reaper
Today Matt and I finished stripping parts off to where it needs to be.
DSC_0705 (Medium) by Justin Sherwood, on Flickr
DSC_0710 (Medium) by Justin Sherwood, on Flickr
DSC_0711 (Medium) by Justin Sherwood, on Flickr
DSC_0712 (Medium) by Justin Sherwood, on Flickr
DSC_0717 (Medium) by Justin Sherwood, on Flickr
Matt didn't want his photo taken!
DSC_0709 (Medium) by Justin Sherwood, on Flickr
Problem areas
DSC_0718 (Medium) by Justin Sherwood, on Flickr
DSC_0719 (Medium) by Justin Sherwood, on Flickr
Bog in this panel
DSC_0714 (Medium) by Justin Sherwood, on Flickr
Driver side rear door
DSC_0715 (Medium) by Justin Sherwood, on Flickr
Driver side under guard
DSC_0722 (Medium) by Justin Sherwood, on Flickr
Boot floor is good
DSC_0720 (Medium) by Justin Sherwood, on Flickr
apart from this bit
DSC_0713 (Medium) by Justin Sherwood, on Flickr
floor is good apart from the tunnel being hacked up
DSC_0721 (Medium) by Justin Sherwood, on Flickr
You may have noticed the rear axle was missing too. Another to add to the collection. I wont ever use this except for the pinion extension shaft and housing.
DSC_0716 (Medium) by Justin Sherwood, on Flickr
What next? Well the roof and boot lid have surface rust under the paint so they will need to be back to bare metal. The rear has bog that needs to be sorted. A few little rust spots, the hole in the tunnel needs to be sorted, and guards need to be done then paint the whole thing.
One step at a time!
Problem areas
Bog in this panel
Boot floor is good
apart from this bit
One step at a time!
- gemsince88
Didn't get much done this weekend.
Removed the early style number plate bracket and welded on the later style as they look better with the slim plates.
DSC_0723 (Medium) by Justin Sherwood, on Flickr
I am still crap at welding! Back to the gas-less wire due to lack of funds. Just as well there isn't a lot of welding to do.
- gemsince88
GM rear axle is now in. Still have to weld the sway bar mounts in though. Everything bar the panhard rod came off the wreck.
DSC_0725 (Medium) by Justin Sherwood, on Flickr
Stripped the front suspension off the wreck. Going to use the springs, sway bar, shocks and left lower control arm. The rest apart from the brake calipers is buggered.
DSC_0724 (Medium) by Justin Sherwood, on Flickr
Started fixing the rust in the sill and found it a little worse than I first thought.
- gemsince88
Work was pretty quiet today so I dismantled the evaporator I'll be putting in. Cleaned all the crap out and pressure tested. Had to replace the tx as it was full of junk. It's good to go in now.
19989219_1835054943171394_4707606138987497638_n by Justin Sherwood, on Flickr
20046328_1835054883171400_427896617770056282_n by Justin Sherwood, on Flickr
Cleaned up the springs, control arms and sway bar. Installed a new ball joint in the right control arm with one that a mate left me. Thanks Greg!
20106447_1835054976504724_5340058981180667178_n by Justin Sherwood, on Flickr
It's good working in a place with all the tools now.
Slowly coming together.
ps. I activated Matts account on here. Went through a few clear not spammer accounts and his was in there
- gemsince88
It now has 4 wheels and no doors. Obviously the front suspension is back in and I took the doors off because I have this strange idea that I can use the doors off the wreck.
DSC_0727 (Medium) by Justin Sherwood, on Flickr
DSC_0728 (Medium) by Justin Sherwood, on Flickr
Fixed the rust here
DSC_0726 (Medium) by Justin Sherwood, on Flickr
Started sanding the roof back with something that looked like a scotchbrite on steroids.
DSC_0729 (Medium) by Justin Sherwood, on Flickr
When I put the AC in this I want to use a clutch fan on the engine but most viscous clutches don't fit. I had one that bolted to the water pump but stuck too far out. So I took it to work and dismantled it.
19959446_1835055026504719_8697322440502984758_n by Justin Sherwood, on Flickr
And cut 10mm out of the guts of it then welded it back together. Cleaned it up on the lathe.
20106828_1835055056504716_8746989100644506231_n by Justin Sherwood, on Flickr
Fixed the rust here
I actually like Persian Sand, its not that bad!
Nice work on the clutch fan, i probably would have just gone thermo though. What'd you pinch the fan off, Diesel?
