GEM77A Reincarnate - The Gem Reaper
gemsince88
Re: GEM77A Reincarnate - The Gem Reaper
Post by gemsince88 »
To be honest I can't remember where the fan came from. It could be from a diesel I stripped or Jackaroo. Had it for decades!
gemsince88
Whats the go moving the galleries around? Huh! I get confused enough as it is these days without you lot contributing to it!
:? :lol:
gemsince88
Yes I have still been doing a little on this.
I test fitted the clutch fan on the coupe and found it works really goodly!
Roof is just about done, just a few undulations that need filling yet.
ImageDSC_0755 (Medium) by Justin Sherwood, on Flickr
A sneak peek at things to come! Drilled the holes for the Kadett headlights.
ImageDSC_0748 (Medium) by Justin Sherwood, on Flickr
I should have enough bits and pieces in this lot to make a set of H4 RHD Kadett headlights.
ImageDSC_0756 (Medium) by Justin Sherwood, on Flickr
So I don't have to use these which are being saved for the coupe.
ImageDSC_0757 (Medium) by Justin Sherwood, on Flickr
Sanded the loose and excess bog off here.
ImageDSC_0749 (Medium) by Justin Sherwood, on Flickr
With a new skim of bog.
ImageDSC_0754 (Medium) by Justin Sherwood, on Flickr
This is as far as I'm going with this bit.
ImageDSC_0751 (Medium) by Justin Sherwood, on Flickr
I don't know when I'll get more done as funds are low and it's getting too cold and dark early.
GEMWRC
Post by GEMWRC »
Hey Justin , good to see this mate .
Love those lights
I wonder if a diesel clutch fan will fit a petrol gem
Get a pair of flood lights they're good for lighting and keep you warm.
What are you whinging about cold. I was fixing an alternator issue the other night in the dark. In my suit lol.
*Re comment on forum stuff. The forums been slowly changing for the best for a while now. I put an announcement up.
If anything should be less confusing. I'll put an updated thing up in a minute.
*Edit - viewtopic.php?f=22&t=48408&p=441429#p441429
gemsince88
Yep I have a flood light. Its a 400w Mercury vapor but I don't need to work in the cold and I'm getting too old for that s*#t so I don't.
Actually its not the age but the mileage! :lol:
gemsince88
GEMWRC wrote:Hey Justin , good to see this mate .
Love those lights
Thanks Daz
The more I think about it I don't think a diesel clutch fan will fit on the water pump.
If you still have your Piazza clutch fan maybe you can modify that. Maybe get different blades or machine it down?
GEMWRC
Post by GEMWRC »
Yeah ok , I do have that and it does need new blades . It fit but I trimmed them down a bit when i fit a 3 core .
I might make another post with some pics of it , it has a flat piece of sheet metal in the middle to change the bolt pattern
Thanks for reminding me ...
gemsince88
I am still trying to get these panels flat. Almost there!
ImageDSC_0035 (Medium) by Justin Sherwood, on Flickr
ImageDSC_0036 (Medium) by Justin Sherwood, on Flickr
Cut the tunnel to suit the remote shifter then cut a piece out of the old car to cover the bodgy hole from the previous conversion.
ImageDSC_0034 (Medium) by Justin Sherwood, on Flickr
When I cut the tunnel from the old car I saw more signs of how violent an impact it had. Not that you really see it in the pic but the tunnel is buckled and the remote shifter is slightly twisted.
ImageDSC_0037 (Medium) by Justin Sherwood, on Flickr
Cut the rear sway bar mounts out of the wreck as well ready to weld in.
gemsince88
The body is as straight as it's going to be. I don't care if it's straight, bi or gay as I have had enough of spray putty and sanding. Anyways it's in primer now!
ImageDSC_0038 (Medium) by Justin Sherwood, on Flickr
ImageDSC_0039 (Medium) by Justin Sherwood, on Flickr
ImageDSC_0040 (Medium) by Justin Sherwood, on Flickr
I reckon blocking the car back is the most relaxing bit! Except for the engine bay which is just a c*#t.
Putting the f*#cking car together without scratching it is the worst bit.
Justin what ever happened to the coupe and Kadett front end you had for it?
I know a guy who's interested in the bits.
gemsince88
Still have it, still have the parts and still going to do it!
Still need a C2 bonnet then
Z20LET
RA Rodeo gearbox
Diesel rear axle with ZZR lsd
Turbo Piazza brakes front, rear with diesel master and Piazza proportioning valve
and painted in Mint Julip green.
I don't have the Z20LET, RA Rodeo gearbox or front Piazza brakes .......YET!
It has been in my head for years now
One day!
Sell the kadett stuff man ;)
gemsince88
Nope. No way! Kadyn is getting the coupe when it's finished. Spent too much already and it'll give me the s*)ts if I don't do it.
