Ok so f*#k you photo bucket, I'm starting again.
Knocked up a heat shield out of aluminium plate, will cover it later with some composite aluminium shielding, I give me a 4/10 for workmanship but time constraints means quality and perfectionism = zero and she'll be right is good enough for now !!!
Turbocoupe75- Becsuse Race Car- the trials and tribulations
- Attachments
- IMG_2055.JPG (71.25 KiB) Viewed 7529 times
- IMG_2054.JPG (96.29 KiB) Viewed 7529 times
- IMG_2053.JPG (91.85 KiB) Viewed 7529 times
Re: Turbocoupe75- Becsuse Race Car- the trials and tribulati
More pics of the 4ZD1 setup
"Small" T28
Piazza turbo manifold + adapter
Water air intercooler
Modified VN throttle body
Rodeo EFI inlet manifold
Head 4ze1
D1 bottom end with dished pistons.
Looking for some larger injectors and a "cheap" ECU option
"Small" T28
Head 4ze1
- Attachments
- IMG_2057.JPG (83.24 KiB) Viewed 7528 times
- IMG_2056.JPG (96.28 KiB) Viewed 7528 times
Whatd you use to make the spacers, phenolic?
Injectors like i said in the other thread - GTR RB26 injectors drop straight into those rails and are 440cc. I think from memory Toyota 7MGTE were also the same size and dimension but dont quote me on that one.
F3ARED wrote:Whatd you use to make the spacers, phenolic?
The spacers made from nylon sort of compound??are just a temporary to get the height right for the barrel cooler until i make them out of aluminium or get some laser cut. The idea is then to use them to make a rear facing plenum and a larger water air cooler with a larger turbo later.
RB26 injectors would probably be the easiest to get hold of but are pricey new!! these ones are 600ish on ebay.
- Attachments
- s-l500.jpg (34.2 KiB) Viewed 7514 times
Still got those rx7 injectors you can have for cheap mate let me know
$200 for the set
$200 for the set
