TD Coupe - FJ20
TD Coupe - FJ20
to answer everyones questions
NO the coupe isnt finished! im sure if it was the planet, including you, would surly know about it cos i wouldnt shut up about it.
NO the coupe isnt finished! and it needs everything done to it to finish it... so why ask?? did u want a list or something??
NO the coupe isnt finished! it will be on the road when its finished.. is it a race or something??
NO THE COUPE ISNT FINISHED!!! STOP ASKING!!!!!!!!!!!!!!!!!
anyways heres a list so i dont have to listen to peopel asking me then question for another 3 years... (once there in red that means there done)
- run fuel lines under car
- put sump on engine
- put flywheel on engine
- put engine in car kinda 1/2 in LOL
- modify exhaust manifold for new waste gate
- modify exhaust for new waste gate and new muffler
- make sure plenum doesnt hit master cylinder.. if it does work out new master/remote set up
- install cooler
- have plumbing done
- wire up car
- wire up computer
- run fuel lines in boot
- ring up about my carpet..? where the f*#k is it??
- put dash in
- makes a center console
- make seat mounts
- put the rest of the interior in
- put rear sway bar on
- do auto boot release
- put in drivers door lock and custom rod
- have alarm installed & keyless entry
- put all the doors guts back in
- put windows in
- put lights in
- put bumpers on (buy them 1st)
- put oil in the diff…
- make gear box x-member
- put tail shaft on
- do the 100’s of other little things
Stereo install at 5% completed
- install cooler
- wire up car
- wire up computer
- put dash in
- make seat mounts
- put windows in
- put lights in
- put tail shaft on
Last edited by Gene FJ20DEBT on Tue Jan 11, 2011 8:51 am, edited 3 times in total.
TD Gemini coupe, sl/e.
fj20det engine-
custom exhaust manifold
modified plenum
XF throttle body
hybrid cooler
EMS duel sport ECU
GT30R
GFB stealth FX BOV
45mm turbo smart waste gate
3.5" mandrel bent tig welded zorst with custom muffler
660cc bosch injectors
4 bosch coils on custom alloy bracket (by BTR)
custom made fuel box system made by BTR aluminum fabrications
alloy oil air separator by BTR
Carter lift pump
Bosch 910 efi pump
upgraded 3/8th fuel lines
hydraulic clutch peddle box
custom clutch
custom tail shaft
custom fuel rail
alloy radiator (by BTR) to come
Alloy oil cooler (by BTR) to come
alloy air box (by BTR) to come
alloy washer bottle (by BTR) to come
17x7.5 lansar rs5 mags
white line springs
koni yellow adjustable shocks
all new nolothene bushs front and rear
adjustable panhard rod
vl/audi vented front disk upgrade
vl disks rear.
front and rear adjustable sway bars
front end KMAC camber kit
all new ball joints.
diff (still to come, next on the list of things to do)
custom spare wheel under boot floor (moved from inside boot)
custom drivers door lock
keyless entry and alarm
custom dash
7-8 gauges and tacho (autometer)
sports wheel, - still to get ( to many to pic from)
RPM 5 point racing harnesses,
6 point alloy roll cage
front race seats
full retrim
Custom rear seat
battery in boot
about $8000 in digital designs, dynaudio & stinger sound system + a s*#t load of hours of fiber glassing
resprayed mazda spicy orange
probably a few other things i missed.
aiming for 300rwhp.. alot of people thing it will be more but i don’t wanna get my hopes up
fj20det engine-
modified plenum
XF throttle body
hybrid cooler
EMS duel sport ECU
GT30R
GFB stealth FX BOV
Carter lift pump
Bosch 910 efi pump
custom clutch
custom tail shaft
custom fuel rail
white line springs
vl disks rear.
custom dash
front race seats
full retrim
Custom rear seat
battery in boot
did you f*&kers get excited thinking there was an update??
well ner ner theres not..
but heres a pick of my brake fluid and clutch fluid bottles i had made up to my specs (the same guy has made my cooler plumbing and over flow for the radiator)
there still raw and need to be polished. but non the less they look hawt
