Hello,
I have been chasing info about a Dizzy, tried to join a Twin Cam forum with no luck. Anyway, I found pictures of a Wasp beside a Stout. It is a 1 1/2 Ton truck going back to the early 60's. Came in any colour you want as long as it was green. Like most early Jap stuff, built like a brick outhouse. There is quite a bit of BS Posted about them by people that have no idea. If you know someone with a Stout, I have some factory service manuals as I used to own one. I have memories of a few, my Dad bought 4 over about a 10 year period. The Lite Stout was grey, and only rated at 1 Ton. It had a smaller engine, smaller wheels and an independent front end. The Cab was the same, and not much more. Theiss was the Toyota commercial distributor, there was a local LWB version. They cut and stretched the Chassis. 6.7 Diff. Low gear was very low !
Wasp and Stout
Wasp and Stout
Regards Chris
Original owner of a 79 TD
Re: Wasp and Stout
Elky,
That is right 15 inch split Rims, twin leading front drums. The back was leading / trailing. Same King pin as a Dyna IIRC 5R three bearing crank, the early ones were a 3R 1900. 25 amp alternator on later ones. Early ones had a strip speedo, and some push button switch's on the dash. Twin round headlights on all. Most were retired to farms. When I saw the Wasp and Stout together I started looking, and there seems to be a number of people with them, not as forgotten as I thought.
Regards Chris
Re: Wasp and Stout
I stored a mates stout for a while, we got it running and replaced a lot of the wiring loom. My mate sold it on when he bought himself a wasp ute!
- redzone (coxy)
Re: Wasp and Stout
Bugger the stout, i want to hear more about the Wasp!
