It is currently Wed Jul 15, 2020 9:06 pm
Post new topic Reply to topic  [ 63 posts ]  Go to page 1, 2, 3, 4, 5  Next
 Post subject: THOMAS4PARTS--FOR ALL YOUR TURBO & PERFORMANCE NEEDS--
PostPosted: Fri Dec 05, 2008 7:28 pm
Thomas4parts for all your performance needs.
We have been turbo charging and modifying Gemini's for over 20 years.
In the Top Ten street registered four cylinders in Australia 1991 to 1996
11.90 at 117 MPH in 1991 G180 TO4 DCOE WEBER
NO NITROUS
11.46 at 112 MPH in 1996 G180 TO4 DCOE WEBER NO NITROUS
9.87 at 137 MPH 2007 4ZD1 NO NITROUS
7.17 at 179 MPH TWIN TURBO 13B ALTERED-- 36 PSI BOOST --(TUNED BY LEE)
--- Fastest 13B in the world to half track---
--- 1.01 60 ft times---
10.33 at 135 mph 808 SERIES 6 13B 14 PSI BOOST
Australia's First GM Ecotec 4 cylinder dragster running 7.30 @ 180 mph with twin Proboost turbos
Double Row Timing Chain Gaskets---Now in stock $20 a set --
Image Image
FOR SALE....
MLS Head Gaskets "G" and "Z"series...$280
MLS Turbo base Gaskets...From$16
MLS "G" & "Z" Exhaust Manifold Gaskets...$35 a set
MLS Gaskets to suit Turbonetics Deltagate or Tial 35mm or 38mm wastegates... $10 each
MLS head gaskets
now in stock. G161, G180, G200, 4ZC1, 4ZD1 and 4ZE1
All of the "G" series gaskets are modified at the front of the head to
accommodate double and single row timing chains, with the bolt
holes slotted and the water gallery reduced for a good seal...
These gaskets have proven themselves in the hands of the fastest G180
powered gemini in the world (YEP8s 8.74 @153mph) and are a must for
any high compression or boosted engines...
G200 gasket setup to put the 1600cc head on------IN STOCK--------
"G" series
Image Image
"Z" series
They are 3 layer and are 1.3mm thick...
$280 Plus postage
MLS Exhaust Manifold Gaskets
To suit "G" & "Z" Series engines...
"G"series
"Z" series
They are 5 layer with a flame ring... $35 a set
MLS Gaskets
They are 2 layer with a flame ring... $10 each
Adjustable Boost Controller Kits
Suitable for external wastegated cars and internally wastegated
cars with dual port actuators...
This can be setup incar for easy adjustment or under the bonnet...
The kit below is to suit single wastegate...
Single wastegate Kit....$100
Twin wastegate Kit......$115Has extra hose and fittings
Trents Heavy duty torque tube rubbers
If your car shutters when accelerating or bangs in the mid section
of your car when you are giving it a hard time, you more than likely
need one of these.
Image Image
TO KEEP MAKING THESE WE NEED A HEAP OF THE STOCK FEET...
THIS IS WHY WE ARE RUNNING SHORT ON THEM, SO SEND ME AS MANY
AS YOU CAN SO WE CAN GET THEM ROLLING AGAIN...
Please contact Trent on 0400168202...
$130exchange (we need the feet for the new rubbers)
$140 posted anywhere in Australia
New cushion donut rubber and new bearing
$135 exchange (we need the old one for the dust rings)
Strengthened Torque Tube shafts $250 Balanced
We can do complete Torque Tube assemblies as a bolt in deal...
  • H/D shaft
  • H/D rubber
  • new donut assembly
  • assembled ready to bolt in
we would need a complete exchange, and can be in a steel or alloy chasing,
early or late... $550 Bolt in
Custom Dizzy's
We are making up and selling a dizzy that is suited to run individual coils...
To suit "G" series... They will run with EMS, Microtech and Haltechs. N/A atm
4ZE1 dizzy cover for running it for a home signal and individual coils...
Image Image $140
Spool conrods
To suit "G" and "Z" series
G180, G200, 4ZB1, 4ZC1, 4ZD1 and 4ZE1
Image $550 a set
Swivel feet valve clearance adjusters
Image $75 a set
We sell all your valve trains needs...
We have been reving our engines over 9000 rpm for 15 years without a problem....
  • S/S valves in all sizes to suit G and Z series
  • H/D valve springs
  • Chromoly retainers and collets
PM Thomas4parts for a price
Big bore fuel rail (17mm internal)
$30 for 400mm
Heaps to make up a rail for "G" or "Z" series engine
We can do custom fuel rails to suit your setups...
Silicon Intercooler Fittings
We have a large range of silicon intercooler fittings, the wall thickness is 6 mm...
  • reducing 90 deg bends 2 1/2inch to 3inch
  • straight reducers ....... 2 1/2inch to 3inch
  • straight hump joiners
  • lots more
Image Image
"Z" series adjustable cam gear
Picture of the 4ZE1
Image $195
Turbo manifolds
They are single entry to suit "G" or "Z" series
ImageImage $550
Chromoly Flex Plates
For big power auto gemini's made from 3/16 plate and will
handle any horsepower you put through it... $300
Billet chromoly flywheel for "G" or "Z"
Image $500
Custom forged piston
To suit your setup
Image From $1000 a set[/b]
The Sprint 500 Haltech EFI computer...
Retail price $1090, we are doing a gemini
terminated harness so we can do a good price on that any other
parts and tuning...
Best way is to PM Lee at Thomas4parts for the best deal...
Air Temp Sensors
These will suit any EFI setup...
Sensor with the wiring plug... $33 posted
Sensor NO plug.. $28 posted
This is one of our ANDRA approved steel bellhousings we have just finished, they
are only for cars that run quicker than 10.99 1/4 mile.
This one is 13B to Supra box...
This is one of the mild steel 8 point roll cages we have just finished,
it is a race car only. ANDRA approved...
A Mazda 1500 we did last year, Turbo, manifold, exhaust system and intercooler mods.
Image Image
Thomas4parts is not a multi million dollar company...
It is a one man part time shop that lee does as a hobby...
PostPosted: Fri Dec 05, 2008 10:06 pm
so you do 4z adjustable cam gears huh price plzzz....
i owned lee's old cream wagon with the g180 turbo once upon a time...lol
my car still runs the modified efi manifold and custom bov he made, does some nice work...
Previously Known As gemzilla1
PostPosted: Fri Dec 05, 2008 10:10 pm
how much to rebuild a hks 2510?
how much waranty does it come with?
Here we go again😒
PostPosted: Sat Dec 06, 2008 2:10 am
Do you have any alloy TB flanges to suit VN-T V8? Chris (macca) also?
Sonic does, but they come in pairs...
“Horsepower makes you fast in a straight line, lightness makes you fast everywhere” - Colin Chapman
 Post subject: customer car
PostPosted: Fri Dec 19, 2008 10:54 pm
This is one of the cars we have done a bit on, this one was a turbo upgrade and new exhaust manifold. It is a series 6 13B and has run a 10.86 at 113mph on 13 psi of boost after our work. Our manifold brings it in to boost at half the revs of the smaller turbo. And now has a reliable boost control setup.
PostPosted: Fri Dec 19, 2008 11:53 pm
Hi this Glen Anderson's twin turbo charged 13B alterd. It is currently the national record holder for it class and has run a best time of 7.30 at 183 mph. The car is only running 28 psi of boost and is the second quickest 13B in the country at the moment, but in the near future it is going to see around 35 psi to 40 psi of boost. It runs a Haltech ecu and I tune it. It runs a Thomas4parts steel bellhousing, It runs turbo's that I supply and we made up the intake piping with one of our blow off valves.
It is only going to get quicker, maybe the first 13B into the six second zone in Australia.
PostPosted: Mon Dec 22, 2008 5:07 pm
Lee's service and quality is second to none.
Professional, prompt and at the right price.
(Item came in the mail today, thanks again matey) 8)
PostPosted: Fri Jan 16, 2009 7:39 pm
These guys make some absolutely mint gear.
I've had the pleasure of seeing some of it in person and using it on my car.
I don't bother taking my car anywhere else now.
PostPosted: Wed Feb 04, 2009 11:28 pm
Thanks bloke hope the MR2 is going hard. :D :D
 Post subject: manifold
PostPosted: Wed Feb 25, 2009 9:31 pm
got my manifold in the post today and i am so happy with it .
you can see how much time lee has put into it and for the right price.
thanks lee. :D :D
PostPosted: Mon Mar 16, 2009 12:34 pm
Do u do rebuild kits for g161?
PostPosted: Sun Apr 05, 2009 10:25 am
Boostin for lyfe!
PostPosted: Sun Apr 05, 2009 1:42 pm
I did not go onto your thread hassling you, I asked you a simple question. BUGGZY
Yes we do T/tubes and we were the first to do so in the late 80"s.
To answer the other question it is actually 23 Years. Lee has owned Gemini's since 1985
and first turbo charged it in 1988 running 13 sec 1/4 miles.
Thanks
I have moved this talk to "OFF TOPIC"
 Post subject: enquiring about g200w
PostPosted: Fri Apr 10, 2009 1:22 pm
currently one of my friends have g200w engine n requiring desiel trannie/tailshaft. just wondering is it really worth doing this conversion in my tf gemmy sedan hes basically said he'll give me motor providing i can get my hands on crossmembers n so forth to do the conversion for the dohc motor.
Also ive heard its hard to source parts for this particular motor...?
are you guys located in thomastown?
PostPosted: Fri Apr 10, 2009 4:24 pm
did u get my pm about the fuel rail
