Thomas4Parts-MLS Head & Exhaust gaskets
Thomas4parts for all your performance needs.
We have been turbo charging and modifying Gemini's for over 20 years.
In the Top Ten street registered four cylinders in Australia 1991 to 1996
11.90 at 117 MPH in 1991 G180 TO4 DCOE WEBERNO NITROUS
11.46 at 112 MPH in 1996 G180 TO4 DCOE WEBER NO NITROUS
9.87 at 137 MPH 2007 4ZD1 NO NITROUS
7.13 at 184MPH TWIN TURBO 13B ALTERED-- 33 PSI BOOST --(TUNED BY LEE)
10.42 at 131mph 808 SERIES 6 13B 13 PSI BOOST
FOR SALE....
MLS Head Gaskets... $280
MLS Turbo base Gaskets... From $16
MLS "G" & "Z" Exhaust Manifold Gaskets... $35 a set
MLS Gaskets to suit Turbonetics Deltagate or Tial 35mm or 38mm wastegates... $10 each
Double Row Timing Chain Gaskets -- Now in stock $20 a set...
For Sale----- MLS Head gaskets that are made to suit G161's, G180's and G200's with single or double row timing chains. The front bolts are slotted and the water jacket is made smaller so it works with both timing chain setups, the bores have been aligned to match the centres of the block so the gasket seals evenly around the bores. These are capable of boost pressures above 50PSI. We have now got aligned gaskets to suit 4ZC1, 4ZD1, 4ZE1 engines.
We can get them in G161, G180, G200, 4ZC1, 4ZD1 and 4ZE1 $280 Plus postage.
We now have the G200 head gaskets. With these gaskets we have taken into account the water jackets for G161 head onto the G200 bottom end------ In Stock Now------
All head gaskets are 3 layer and 1.3mm thick...
MLS G161, G180, G200 gaskets.
MLS 4ZC1, 4ZD1, 4ZE1 gaskets.
This is a couple of gaskets from our new MLS range
From the top Left clockwise, they are to suit...
TO4 Split Pulse-- $20
TV Flange--------- $20
TO4 Single entry- $18
T3----------------- $16
T04 Euro Flange- $18
T2----------------- $16
TA45-------------- $20
These Turbo gaskets are not single use gaskets like most of your normal turbo gaskets. These gaskets are good for a couple turbo changes and seal like no other....
We have MLS Gaskets to suit Turbonetics Deltagate or Tial 35mm or 38mm wastegates... 2 layer with a flame ring... $10 each
We have MLS gaskets to suit "G" and "Z" series exhaust manifold. These gaskets are 5 layer with a flame ring...$35 a set
"Z" series
"G" series
To order any of these Gaskets, we need the following....
You need to PM Thomas4parts with your address and the engine with a bore size you wish to buy...
With this received I will PM you back with our Bank Details, and a total you need to transfer. We need the transfer to be tagged with your username for easy ID of your payment( if the bank will only tag with numbers or your username will not work), PM me with the tag you put with your payment. This way I can look for it in our account...
Info on Lee's parts...PM Thomas4parts
Click on the orange thomas4parts to send a PM.....
FOR SALE....
"Z" series
"G" series
Re: hey
wtf? lolScratch09 wrote:hey i need a head gasket both sides of head for the exhaust and manafold asap when u recon u could get them for me cheers mate
