Hi peeps
As you would already know from hotgemini and other forums, I custom
make all aluminium products from Intercoolers, radiators, piping, catch cans,
plenums etc etc, so if your in the market for any custom fabrications you
just cant buy then think the name BTR and I will look after you every time...
regards
LeRoy
(08) 83765522 or 0438 327510
***BTR ALUMINIUM FABRICATIONS***
BTR PERFORMANCE FABRICATIONS
rear shed 3 davis street wingfield south australia 5013...
Also this is a full custom gemini wagon that if it could be made from aluminium
it has been from full custom plenum to water tranfeer tubes and rocker covers.
This would have to be one of the nicest wagons Ive seen along side dreggo's.
Below is a couple of the engine.
The one below is a pic of the custom rocker cover and if you look at the
heater/fan box you will also notice the cut out for the clearance for the
cover as it sits up taller than the original... The other bit next to the rocker
cover is the base that was router cut by a boat builder for me...
LeRoy
LeRoy
Hi peeps
Well I’m going to take this time to let you all of ozgemini.com know that we have moved
and ill be in full swing by FEBUARY the 1st 2006. We are there now but only doing odds and ends...
The old place was just a little too small and wasn’t working out so over the last 6months
we have been searching high and low for a bigger and better place..
we still will be offering our aluminium and performance upgrades at the ozgemini.com
discount as per usual, and my very good friend has just opened up his own panel shop as well
in the same complex, he specializes in full resprays, airbrushing and fitment of
full body kits and wide body kits....
RING BTR ON 0438 327510 and get your quote today on intercoolers, piping, microtech
components, turbo smart, silicon hosing, catch cans, radiators from std right up
to HD drift spec/race ones..
3 Davis street, Wingfield, 5013
Regards
LeRoy
Regards
LeRoy
well its almost been a year since the move and I would like to take
this oppertunity to thank all that used BTR last year for there aluminium
work and I hope to hear from you guys in 2007 and that you have a safe one..
regards
leRoy
www.btr-performance.com.au
regards
leRoy
