Bolt in bonnet struts
Have you got a great deal to offer all the members of OzGemini? If so Post the details here.
This is not for Private "for sale" add's
gemsince88
Post by gemsince88 »
Sorry to say people but I will no longer be doing these. They are simply not worth my time. I am over the idea as well as people wasting my time. If you need bonnet struts for your Gemini get hold of Grant Page on Facebook, he does them for $100 delivered.
Now if you really, really really want a set of these then call my work on 0249612122.
No cutting or drilling, just a couple of bolts. Specifically designed for Gemini!
These are custom struts made where I work.
Please read all the information below before puchasing!
As of July 1 2018
$180 + postage per pair
Credit card or direct deposit
Image36302462106_bc3ea556c2_z by Justin Sherwood, on Flickr
Can do stainless as well
As of July 1 2018
$280 + postage per pair
Image36302706446_aa85ef3342_z by Justin Sherwood, on Flickr
ImageFB_IMG_1501750216104 by Justin Sherwood, on Flickr
ImageFB_IMG_1501750247775 by Justin Sherwood, on Flickr
Just one thing with the stainless struts is that the ball cup at the bonnet end is silver painted zinc plated steel as these angled fittings are not available in stainless.
Or a combination of stainless and black.
Image36347284845_c0045f5559_z by Justin Sherwood, on Flickr
Can also supply new tailgate struts for wagons in black or stainless.
Image35950713640_d809da652f_z by Justin Sherwood, on Flickr
Warranty Information
As these are usually installed by the customer then,
Straight from the boss's mouth.
"There is 12 month warranty on the strut only providing that it is not bent, shaft damaged or label removed."
I would imagine that if something like a bracket was not made properly or the wrong parts sent then it would be replaced.
Since I have been making these a few issues have come up and need addressing.
1. On the black sets the steel extension is prone to rusting so these are now painted black along with the angled ball cup.
2. On the stainless sets the ball stud at the bonnet end is not available with 6mm thread in stainless so these are 10mm ball studs with 8mm thread turned down in the lathe and rethreaded. The issue is the die will not cut the thread on the stainless cleanly and so look rough with some more than others. I do try and check this when doing them but my eyes aren't the best and when I'm busy some slip through. If you do end up with a set of bad ball studs, as stated above, let me know and I'll send another pair out.
Fitting destruction's!
There is 2 ways of fitting
1 Fit the entire assembly
2 Fit bracket and balls separately
Remove front bolt from bonnet hinge and replace with ball.
Image35950117770_23e3a66a8d_z by Justin Sherwood, on Flickr
Loosen all top guard bolts and remove the bolt that lines up with the bracket. Slide the bracket in between the 2 panels, replace bolt and tighten everything back up. NOTE there is a LEFT and RIGHT bracket which I usually mark as such. To be sure when fitted the ball on the bracket sits slightly further forward of the guard bolt.
Image36178227612_ca641e65a1_z by Justin Sherwood, on Flickr
To remove ball cups from balls.
Image36210242221_69c6788ddf_z by Justin Sherwood, on Flickr
Image36178243892_fd804e642a_z by Justin Sherwood, on Flickr
Image36210257001_e9906c0e48_z by Justin Sherwood, on Flickr
Image36302477176_e4223c5695_z by Justin Sherwood, on Flickr
Seano
Re: Bolt in bonnet struts
Post by Seano »
Keen!
How do I purchase?
gemsince88
Relocated to first post
I tried to link to all the details here for people on facebook who ask about them.
I keeping having comments deleted by halfwits.
