It is currently Sat Jul 04, 2020 10:14 am
Post new topic Reply to topic  [ 40 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: LOK's Big brake upgrade kit.
PostPosted: Thu Jul 16, 2015 2:44 pm
LOK15 wrote:
pipe on the lathe can be turned into rings ;)
Ha when I had access to a lathe I bored and parted off mine out of a solid bar of K245... a bit of over kill, mild steel tube would be fine.
http://www.ozgemini.com/forums/non-tech ... hp?t=26329
PostPosted: Tue Jul 21, 2015 4:02 pm
yeah , its only a locator , not a load bearing item.
PostPosted: Mon Jul 27, 2015 8:59 pm
Doing another run of hubs atm , be ready in 2 weeks.
PostPosted: Thu Jul 30, 2015 7:23 pm
A few brake lines , custom made for gems
PostPosted: Tue Aug 11, 2015 9:24 pm
Currently all sold out , have a new batch of hubs arriving hopefully later this week.
PostPosted: Fri Aug 14, 2015 5:28 pm
Prototype TC-D-E adapter for VX master has been made. Will be for sale after all testing is done.
PostPosted: Wed Aug 19, 2015 7:55 pm
Lasted 2 hours and all but sold. Have the 2 x sets on ebay only atm.
PostPosted: Thu Aug 20, 2015 12:00 pm
Just curious LOK,
In the photo you seem to have one set of 4 stud hubs drilled for 115mm instead of 100mm?
Also, any progress on spacer rings for rear disc conversions?
PostPosted: Thu Aug 20, 2015 2:34 pm
yes , 1 set was a special order 114.3x4 , just awaiting that person to put their hand up as i cant remember who it was.
No further progress on spacer rings. Im hoping to have the car up on blocks this weekend to make a start on the rears. Already have the discs drilled waiting to go!
PostPosted: Wed Aug 26, 2015 5:19 pm
Hi LOK
When have you got more front hubs available ?? & how are the rear sets going .
Thanks Josh
PostPosted: Thu Aug 27, 2015 7:21 am
once all current hubs are paid i'll be looking into another order. Have the hardware for the rears , just not the time atm.
PostPosted: Sun Aug 30, 2015 7:23 am
Ill be keen on a set when they become available again please. So just to clear a couple of things up, i have a 77 TX sedan. What front calipers would i use with this set up? If i got a set drilled 5 stud, this would slightly simplify a rear disc brake conversion as i could use 5 stud commodore discs without having to get them drilled to 4 x 100? As my 13 x 8s wont fit anymore theres no real benefit in staying 4 stud (unless i am missing something?)Am i on the right track?
Cheers,
Matt
PostPosted: Sun Aug 30, 2015 7:29 am
Cheers,
Matt
the front calipers would be the VX ones.
Yes ,your 13x8 wont fit. You need a minimum 15" rim to clear the calipers on the front. 14" may fit on the rear with a conversion , but having 2 different wheels is expensive in the long run.
The rears , if you were to convert them , you'd need new axles. Its not legal to redrill discs ( unless racecar , but then you compromise integrity with heat from hard braking on corners )
Im in the process of doing a rear disc conversion to 4 stud. I have the discs and back brake hardwae , just not the time currently to fit it all up and get the needed info to make it a bolt on no mod kit.
PostPosted: Wed Sep 02, 2015 12:48 pm
Cheers,
Matt
Hi Matt,
Going 5 stud on the rear does not necessarily simplify matters. Suggest you get a cost for axle shorten and respline before you decide. It was pretty line-ball last time I looked into it. If Lok can offer 4 stud discs and conversion rings at a reasonable price it will romp it in for price.
PostPosted: Thu Sep 03, 2015 4:36 pm
Or you could buy my 5 stud hubs and rotors :D
