alloy radiators
Use this Forum to organise Group Buys
Locked
BAD 44u
alloy radiators
Post by BAD 44u »
The price for 5 - 10 55mm thick alloy radiators with mounts and inlets customized to each buyers order is $650 add $35 for thermo mounts.
They do take time to make so if this works out don't expect them overnite.
there will also be a price for a group buy of 1-5 and if there is 10 or more we can get another price.
orange_gem
Post by orange_gem »
im in for this. a lil thicker would be better about 70mm. my car is at motos and on dirt going sideways all the time so a lil bigger would be great. how much did he say for a 1-5 group buy.
are all gemi radiators the same size and mounts?
Keepin it sideways in the territory
sly380
Post by sly380 »
is this from pwr?
i might be keen
Here we go again😒
BAD 44u
Post by BAD 44u »
this is from btr in the ozgemini advertisment there are pics of his work in that section. he hasn't worked out a price for 1-5 yet.
All the cores are the same but the mounts can be changed depending on what engine you are running. some need to be under the radiator support for more space. also you might want the inlets and outlets in different places.
orange_gem
i want it exacally the same as the standard one just a lil wider about 50mm. standard hose placement and everything.
BAD 44u
Post by BAD 44u »
here is the guys number if you need more info 083765522 or 0438 327510
he's name is leroy. it look's like there will only be 2 or 3 interested so ill give him a call monday and get a price.
EVL WON
Post by EVL WON »
Round 2 Group Buy Anyone?
“Horsepower makes you fast in a straight line, lightness makes you fast everywhere” - Colin Chapman
Locked
