Sarah's (Gemigirl) TD Sedan
- Frederick Stienheld
- Site Admin
Engine: Isuzu G180 1.8-litre single cam, bored to 2l. Port matched and flowed head, 3-angle cut valves, heavy duty valve springs, 30-70 Ivan Tigh camshaft, double row timing chain, forged flat-top pistons, moly rings, balanced conrods, crankshaft and flywheel, RPM heavy duty clutch, Jap. electronic distributor plus igniter, electronic coil, 8mm leads, twin 40m IDF webers, 4-2-1 Lukey extractors, 2 1/4" exhaust with 3 inch tip, custom front and rear wiring harnesses.
Body: Mitsubishi Icebell Blue metallic paint (body) with badges removed, mid grey/silver metallic paint (under body), chromed diff cover plate, engine bay painted body colour, engine block painted body dark blue (high temp), cylinder head painted under body colour (high temp), chromed engine bay equipment, braided hoses, Holden GTS Monaro side mirrors, re-chromed front and rear bumpers, tinted windows,
Interior: Mazda MX-6 front seats - recovered in dark/light grey velour with patterned insert, , Gemini rear seat - reshaped with the same trim as the front seats, light grey velour hood lining, re-skinned and custom designed dashboard, custom full panel MDF door trims covered in light grey velour and patterned insert, dark grey plush pile carpet, modified centre console, Autometer 2 1/4" oil pressure and volts gauges, remote boot release switch in glove box (from VK Calais), remote central door locks and rewired harness. Custom boot - MDF panels covered in light grey velour (houses both amps, CD stacker and DSP unit).
Suspension and brakes: Gemini 5-speed manual, balanced tail shaft, Gemini front cross member with standard discs and re-kitted callipers, Gemini ZZ/R (Japanese) 4.11 LSD with ZZ/R discs and single piston sliding callipers, Bendix sports brake pads front and rear (rear pads same as RX7 series 1 pads), Whiteline 24mm front sway bar, Whiteline 13mm rear sway bar, standard panhard rod, K-Mac 35mm lowered front springs, K-Mac 50mm lowered rear springs, Monroe GT Gas front shocks, K-Mac Gas shortened rear shocks, nothalene suspension and driveline rubbers. Most under-body parts painted high temperature dark blue.
Wheels and tyres: Vault savannahs 17-7 with 205/40 nankang rubber
Stereo: Pioneer head unit, Pioneer DSP unit, V12 amp, Alpine component speakers, Alpine 6x9 speakers, Lanzar amp, Lanzar 10-inch sub
