Cazz wrote:
I think most of these responses are kind of assuming we'll be using the same hillclimb track. Although I do think it would be cool next year as they would've finished the extension, we can't forget that there will be other tracks around. Have you guys thought about the driver training track (will check the name and update my post when I find out). It's not a fast track, but is technical.
Edit: Marulin Driver Training Centre. It's much closer to SA, Victoria and Canberra. Also it's near Golbourn which by the looks of it has a lot of forestry which will make for a good cruise route.
Another suggestion is close to Sydney Motorsport Park, as the go kart place there is apparently excellent. But at the end of the day, we have to do what will make Cowie happy.
Maraluan Isn't too bad. I haven't raced there but told it's pretty laid back .
As for the Ringwood hillclimb track yeah your right it ISN'T required that we use that track again.
Lot of Pros to using again but I'm not phased.
Also I think someone mentioned something about Kiama having one?
There's a hillclimb in Cooma but I wouldn't suggest it as it's too close to Canberra which = gay.
If we had enough numbers we could look at doing a full blown track day at Goulburn. I think to run on your own it costs about $256 (which includes cams licencing etc) not saying we rule it out but it might be a bit hard for some to afford to run there.
Also it doesn't
haveto be a hillclimb can be some small supersprint, motorkhana or even a skid pan?
Might be worth sussing out somewhere with hills. After Roddys slider stories I wouldn't mind getting into that again.
Cowie is keen for go karts so got to ensure there's one of those around to.
