15's for $1500 , who would be interested in the challenge?
15's for $1500 Competition
DrewZa86
Post by DrewZa86 »
LOK15 wrote:Hers a good starting point for some of you
http://www.ebay.com.au/itm/230823677313 ... 1423.l2649
Good luck to bidder these a cheap as f*ck and about a week too late for me. FML
Gene FJ20DEBT
Post by Gene FJ20DEBT »
stubbsy212 wrote:After seeing gene's 17.1 with a 4zd1 with twins, i dont see this comp being won any time soon.....
stock engine dude.. dosnt even have a cam in it. :wink:
plus my tires have a fairly small rolling diameter, so it runs out of puff about 3/4 track.. it would be in the 16's with just a taller/standard tire height
plus i have konis set to rock hard so if i try take off to hard from the line it axle tramps like crazy. if i softened them up i would get off the line a little quicker also
i wouldn't use mine as a comparison for this comp. its not really set up for the drags
LOK15
Post by LOK15 »
plus its not a G series motor ;)
LOK15
Post by LOK15 »
So did anyone from here get the carbies?
and when is someone else going to add their car to the list?
redzone (coxy)
Post by redzone (coxy) »
I won this comp back at jamboree 2000, 15.4 with a g161z with 120 thou bore, stock crank, twin 42dcoe's, home ported head, reground cam etc
LOK15
Post by LOK15 »
So here is the proof it can be done.
I will add , coxy did this whilst being an apprentice mechanic, so it goes to show even will little experience , it can be done!
not a stab dave , just showing its possible without big $$$ or tonnes of experience.
geminilover3236
Post by geminilover3236 »
redzone (coxy)
No stab taken, it was my first ever performance engine build, and only my second ever engine build..
Twin webers, decent cam, home ported head, 120 over 1600, extractors, & get it dyno'd. Job done..
elky
Post by elky »
dont forget micheals td, didn't that do a pretty good time with a single weber?
LOK15
Post by LOK15 »
elky wrote:dont forget micheals td, didn't that do a pretty good time with a single weber?
I'll ask him next time he calls ( only spoke 2 nights ago )
76_tx_gem_sedan
Post by 76_tx_gem_sedan »
I hope whoever got those twins is entering....
I missed out, unlucky timing with bills and other expenses meant I had to let it slide.
Otherwise I'd be joining u in this challenge Lok.
LOK15
Post by LOK15 »
I have twins , but im going to go the single carby route and see if that'll do it.
redzone (coxy)
yeah a 32/36 will do it for sure, be easier with twins though. you will have to pay special attention to porting the intake manifold..
DrewZa86
Post by DrewZa86 »
I doubt i'd rebuild my other engine before the 2013 nationals [or my car for that matter] but might of came under the budget.
G161z with 5 speed and extractors [bought as whole car] $200
Twin 40mm Sidedraft Delorto's [minus shipping] $100
Manifold with linkages [Pending] $220
Rebuild kits $80
GoForGreen
Post by GoForGreen »
I'm going to try this with one of my geminis.
I got bored and pulled the head off and found some nasty piston slap, so a rebuild is a week away.
Seems very possible to me. I'm keen to make my gemini faster than my vt
Locked
