LOK15's entry TF "Moonshine Madness"
15's for $1500 Competition
LOK15
Post by LOK15 »
I will be using a TF sedan picked up from Moby vic's
And the engine bay as i got it......
Yes , that is oil covering everything.
Car is factory 4 speed 1600cc's of 25 second goodness ( it runs on 3 cylinders )
It does have tuned length extractors and a 2'5" exhaust already fitted.
Originally had a locked diff , but i replaced that back to factory open centre diff
Plans are to rebuild this motor into the 15 second "moonshine run" vehicle it was always destined to become!!
Costs:
Car $175
LOK15
Post by LOK15 »
OK , so here is the plan.
G161 to be bored and 2lt pistons put into it
G161 TX head will be used , home port job.
Intake i'll leave a secret for now.
Dizzy will be played with a little , basically changing the timing total.
Camshaft will be roughly a 30/70
Will be running exhaust currently incar , which is 4-1 snakes ( you can see them kinda in the pic )
4 speed box and stock open centre diff.
Planning on pulling motor out in the next fw weeks and stripping it down in the shed.
redzone (coxy)
Post by redzone (coxy) »
30/70 wont be enough i dont think
LOK15
Post by LOK15 »
redzone (coxy) wrote:30/70 wont be enough i dont think
Using what i have here
Andrew64
Post by Andrew64 »
we have a 40/80 8)
Image ©2009
redzone (coxy)
Get a regrind lok, surely you could do that within budget
LOK15
Post by LOK15 »
redzone (coxy) wrote:Get a regrind lok, surely you could do that within budget
I have various cams here , even have a 40/80 , but dont really want to use it.
There might be a 35/75 amongst them all , but will have to get some spare time to see about finding lift and duration.
elky
Post by elky »
what's wrong with the 40/80? valve springs or lift?
LOK15
Post by LOK15 »
elky wrote:what's wrong with the 40/80? valve springs or lift?
pistons need to be flycut
redzone (coxy)
In true 15's for $1500 fashion, a flycut is but an angle grinder away!
geminis are hektik (y0)
Post by geminis are hektik (y0) »
Get to it! :lol:
LOK15
Post by LOK15 »
if i do flycut , it'll be done with a die grinder , not a normal grinder.
elky
Post by elky »
LOL that is pure ghetto goodness right there!
vivoacer
Post by vivoacer »
Hows the progress on this going?
LOK15
Post by LOK15 »
due to lack of motivation , its still sitting in same spot unfortunately. I have 2 cars that i have to finish first before easter
Locked
