It is currently Sat Jul 04, 2020 9:19 am
Post new topic Reply to topic  [ 462 posts ]  Go to page Previous  1 ... 27, 28, 29, 30, 31
 Post subject: Re: #SuperGrover - the running on 8 cylinders again supergem
PostPosted: Tue May 29, 2018 7:01 pm
So my water pump arrived , ordered an STC483 , but found out i really needed an STC488 , so now have to hope i can return it.
Also stumbled onto the original distributor , that doesnt pull itself apart , tomorrow i'll swap out dizzy's and see if it'll start so i can move it!
PostPosted: Tue Jun 12, 2018 6:21 pm
Machined the water pump , forgot to take a piccy, but hopefully tomorrow afternoon i'll fit it and do a pressure test on the radiator.
PostPosted: Wed Jun 13, 2018 9:26 am
You can re-load that video of this power skid..
Will accept at least a 1 meter oh and no foot brake.
PostPosted: Wed Jun 13, 2018 5:06 pm
once its running again , i'll get someone to hold the camera!!
PostPosted: Sun Apr 19, 2020 2:59 pm
So im going to update this a little..
Was meant to be ready for 2020 gem nationals, but the corona virus cancelled EVERYTHING!, so i'd been tinkering away at this thing to get it repaired and painted for the big cruise day. Anyways... Car in shed, rust cut out and repaired, primered and painted, then interior fitted into it. Pics can tell the story!!
Here you can see someone had stripped the paint back and let it sit ( wasnt me, but i did have it sitting outside for quite a while ) so it was taken back to fresh metal.
Laat pic here, is the starter motor, showing its mod to be able to clear the steering column.. Now dont forget, the column was moved over approx an inch. also replaced the welch plugs in the blck as they were corroded and one was leaking badly.
PostPosted: Mon Apr 20, 2020 11:34 am
Way more than I got done on my Geminis...
PostPosted: Wed Apr 22, 2020 6:17 pm
Fitted bumper and grill on, but didnt have all the bits i needed to get it all lined up right.. Tomorrow job!!!
Roof lining is in, now to be stretched out and windows roped in.
PostPosted: Fri Apr 24, 2020 9:16 pm
Front and rear screen are in, grill is cable tied into place, all thats left is put passenger seat into car, take it off the stands, coolant in radiator, and fit bonnet. Then it should be good to test drive and make sure everything still works and doesnt leak anymore water!!
PostPosted: Sat Jun 13, 2020 6:56 pm
Scoop bonnet getting some love.. HAd a bat s*#t on it eating the paint, and had a few blemishes i wasnt happy with the first time, so here we are.. doing it all over again!!!
PostPosted: Sun Jun 14, 2020 9:26 am
Actual bat s*#t or?
PostPosted: Tue Jun 16, 2020 3:37 pm
Jonno wrote:
Actual bat s*#t or?
Yes. its highly acidic and eats paint if you leave it on too long.
PostPosted: Thu Jun 25, 2020 6:20 pm
So bonnet is ready for undercoat, and the speedo issue has been fixed, had a broken cable!! Also modded shifter so it now only starts in park, as the lnkage is slightly out and it wuld start in drive!!! Almost ready to go to a new home who will maybe drive it instead of have it sitting around like i do!
