TC Gemini Coupe
This Forum is here for each member to post pics of his/her Gemini’s. Keep it to one thread per car.. if you get more pics etc, add them to your existing thread, DO NOT start a new one
arrow
The Grand Master
Re: TC Gemini Coupe
Post by arrow »
great to see it coming back to life. keep going doing a top job
GemmiCoop
Re: TC Gemini Coupe
Post by GemmiCoop »
arrow wrote:great to see it coming back to life. keep going doing a top job
Thanks!
I'm pretty sick of panel work.
I'm getting abit side tracked, and went looking for a twin cam motor, and ended up buying 2x.
Plan is to get 1x complete running motor out of these, maybe even 2x! - Watch this space!
twin cams.jpg (482.66 KiB) Viewed 550 times
Build thread- viewtopic.php?t=48434 - TC Coupe Project - LH Torana - D22 Navara.
Pics or it didn't happen
GemmiCoop
Re: TC Gemini Coupe
Post by GemmiCoop »
i cut out the back left chassis rail section as it was abit rusty - while i'm there !!!
the whole thing is now ground back, weld through primered, and screwed together - ready to weld.
screwed 4.jpg (365.94 KiB) Viewed 472 times
screwed 2.jpg (309.56 KiB) Viewed 472 times
screwed 1.jpg (336.2 KiB) Viewed 472 times
GemmiCoop
Re: TC Gemini Coupe
Post by GemmiCoop »
more pics
screwed 7.jpg (274.26 KiB) Viewed 471 times
screwed 6.jpg (220.38 KiB) Viewed 471 times
screwed 5.jpg (303.49 KiB) Viewed 471 times
GemmiCoop
Re: TC Gemini Coupe
Post by GemmiCoop »
last ones
screwed 12.jpg (302.72 KiB) Viewed 470 times
screwed 11.jpg (234.61 KiB) Viewed 470 times
screwed 8.jpg (343.87 KiB) Viewed 470 times
GemmiCoop
Re: TC Gemini Coupe
Post by GemmiCoop »
All Welding done.
GemmiCoop
Re: TC Gemini Coupe
Post by GemmiCoop »
Everything ground, primed, time to do the nikki work, deadener in the boot etc.
GemmiCoop
Re: TC Gemini Coupe
Post by GemmiCoop »
So i've been going back and forwards between panel beating, and the twin cams - which need a few bits here & there.
So I chopped up 2x crappy EFI manifolds, got some laser cut DCOE flanges, got the EFI manifold flanges machined, blasted, roll pinned them in position, got them welded, and hand finished them. only roughed out for now, but we have 2x pairs of DCOE manifolds!
inlet manifold pic.jpg (810.87 KiB) Viewed 406 times
GemmiCoop
Re: TC Gemini Coupe
Post by GemmiCoop »
So the twin cams didnt have distributors, so with abit of help from Ozgemini users doing abit of measuring etc ive worked one out that will work!
modified dizzy.jpg (501.36 KiB) Viewed 398 times
GemmiCoop
Re: TC Gemini Coupe
Post by GemmiCoop »
Modified 2x sets of LHS Engine mounts to fit the DOHC into the Gem.
GemmiCoop
Re: TC Gemini Coupe
Post by GemmiCoop »
Somehow one of the water manifolds was cracked, so that one has been welded up, and both manifolds drilled, tapped, etc to common NPT sizes and all holes fitted with Bungs to block off until required for temp gauge, heater pipe etc.
water manifold.jpg (283.16 KiB) Viewed 194 times
GemmiCoop
Re: TC Gemini Coupe
Post by GemmiCoop »
Its time to get the back end of the car re-painted, so i've got it back to drivable condition.
Fuel tank back in, battery in, and I had sent my instrument cluster away to be checked out, a factory tacho fitted, and everything tested and calibrated, plus LED light upgrade.
