4A10SHN - Rebuild #2
firebug
Re: Rodeo Rebuild for [4A10SHN]
Post by firebug »
Reassembly after fresh paint is by far the funnest part of any rebuild... :)
Josh
Post by Josh »
I agree!
redzone (coxy)
Post by redzone (coxy) »
Yeah it's like a big model kit!
Josh
Post by Josh »
Finally got the pedals sorted
Got the cutter from USA to put valve reliefs in the pistons
Waiting for the custom billet cam
Waiting for a CNC flange for the intake manifold
I need to get my touch screen dash and finish that and the floor plates then drop everything off to be coated black :)
Re: 4A10SHN - Rebuild #2
Josh
Post by Josh »
Some more updates
Holden202T
Post by Holden202T »
f*#cking lovely work :)
what he said
GEMWRC
Post by GEMWRC »
Metalcraft porn productions
f*#cking hell, getting better and better by the minute.
Hey Josh, noticed the O rings to seal the inlet manifold instead of gaskets, just curious what the train of thought was and how you reckon theyll go long term with heat cycles?
Josh
Post by Josh »
F3ARED wrote:f*#cking hell, getting better and better by the minute.
The cylinder head should only ever see around 80 degrees so I think they will be fine with some Nitrile or silicon based O-rings to handle the methanol as well :)
Holden202T
really its no different to the o-rings on injectors and such, they don't normally fail that often in place, its when you pull them apart they die! (in my experience anyways)
but yeah certainly an o-ring rated for fuel and high heat would be safe insurance!
DR_GEM
Post by DR_GEM »
Unbelieveable
Dead serious now - how much for a carbon copy of that inlet manifold and plenum?
DR_GEM wrote:Unbelieveable
viewtopic.php?f=30&t=48429
:wink:
DR_GEM
Post by DR_GEM »
Thanks Jonno
Two things - need the larger runner diameter and mine is 4z so will cause drama for oil drain
Josh - let me know dude
