i asked a rupuatable engine bulider the correct volume for what i was after and bent up some 4 mill aliminium on the bender to the desired shape,then welded the fabricated piece to the bottom on the original flange which i cut on the band saw .
made a cover plate for the back section drilled the holes to 5.5 mill and tapped them to 6 mill .
bought a holden v6 throttel body and added that also
easy as pie
im not real sure when im taking the car to race,its been sitting in the garage collecting dust (it does that a lot) but hopefully azz boy (mr0fj20)and myself can get out there in the holidays sometime!ill post the time slip up that night!
Ey bro, im new to this forum im all the way in Perth WA, your gemini is off the hook, it looks killer. i got a tf 1982 model doing bits & pieces. as i was lookin at you pics i seen your boot and that was neat! just wonderin if you can fill us in wat you did.
Sweet ride!! I have a similar set up running a gt30/35 @ 20psi. Sounds like you got a good tune happening. I still need more cash for more dyno time! Love to see those sort of power figures on an isuzu engine too. It's the only way to go! Great work there mate!!
