My green TX coupe, 4ZD1T 422rwhp vids page 15
yeah i kinda like the contrast between clean tasteful exterior and the batshit insane engine bay almost every person that hasnt seen it before, when they see under the bonnet, goes HOLY f*#k!!!
AND YES ITS RUNNING FOR THE FIRST TIME SINCE NOVEMBER 2001!
woooooooooooo0000000OOOOOOOOOOOOOOooooooooooooo!
just gotta keep tapping the numbers in so she idles nice etc. not much req'd to get it driveable now.
yeah had it running but the cam dowel pin worked out of the cam drive and the cam spun in relation to the pulley, result = 2 bent valves. i'll probably have it running again by the end of the week but i havnt had time to finish the 8 other jobs i needed to do to get it useable! should be on the road very very soon thoughmarc_greinke wrote:You get the Gem going Dave? Ryan was telling me you had some mishap last week, hoping to see this out at Jambo on the weekend
yeah i want to get it driveable so i can get the chev down to my workshop! i made a longer dowel now so it is mechanically held in by the cam bolt washer.. i'm gonna take the opportunity to finesse a few things i wasnt 100% happy with while its apart though, like the wastegate outlet pipe.
UPDATE!
well i thought f*#k it, if i'm changing the wastegate outlet pipe i may as we'll put a smaller gate on it, so it's getting a 50mm one. and a smaller wastegate outlet pipe and some new hpc coating on it..
fuel system brackets nearly done, clutch hydraulic line made, just needs a reservoir and i should have a working clutch system.
i also sent the haltech back with the 4 bar map sensor so they can work out why the map sensor wasnt reading properly!
