Nissan VG30ET V6 Turbo, TF Gemini, went to the dyno!
DryftKult
Post by DryftKult »
so theoretically the t700 from an auto v6 commo will bolt up to one of these?
I would only need to sort out the flex plate and converter yeah?
that would make my vg20et conversion idea much more appealing.
iViLe
Post by iViLe »
nup, unless you use an adapter plate, the t5 box uses a separate bell housing to bolt to the Nissan engine, where as the bell housing on the Nissan boxes is part of the gearbox. But I cant see why you cant just use an auto out of a Nissan 300zx, navara or a pathfinder? I'm sure there as good as a th700.
VG30ET + white gemini wagon....
6.0L Gen4 + T56 Powered 64 Chev Belair.
I like burnouts.
http://www.youtube.com/watch?v=XW0UdyfvflM
http://www.youtube.com/watch?v=iXI-vFI-E3U
DryftKult
Post by DryftKult »
I'm only worried about the size and how much I'd need to stretch the transmission tunnel.
if a 300zx auto will fit I'm happy to use one, but I don't want to lay out only to find out that the seats won't even fit because the trans tunnel has to be widened.
iViLe
Post by iViLe »
Might be best to go to the wreckers and put a nissan auto next to a trimatic, see what the differences are.
I like burnouts.
iViLe
Post by iViLe »
Yeah head gasket has blown again, yep punching it.
I like burnouts.
iViLe
Post by iViLe »
Powder coated the rocker covers crinkle black.
Covers again.
Side shot of the pos.
Gutted the inside of the upper plenum for better upper rpm flow. Had a aluminum plate welded onto the top. This and the bottom will also be ceramic coated.
Relocated the throttle body to the side, changed from the stock 52mm to a KA24 60mm Throttle body.
Inside the plenum.
Some axle snapping Yokohama A048 semi slicks, 225/50/15.
Bought 12 Bosch 035 injectors for $5each, 392cc at 3bar.
New headers I made, just need to finish smoothing them out and welding some flanges to the ends. Then have them ceramic coated.
FJO Wide band kit, laptop data logging etc.
B&M Fuel pressure gauge, blackout style.
The only thing I need to get now is a new turbo, Looking at a Garrett GT3582r .82 exhaust housing, internal waste gate. Or similar aka gt3540r or xr6 turbo. So if you have a good one pm me!
I like burnouts.
DryftKult
Post by DryftKult »
8)
iViLe
Post by iViLe »
Well I just blew the head gasket for sure, well water out the exhaust is a good sign its gone, still drove it home.
f*#k me it flew all over the place in 3rd gear, 4th gear and pop goes the radiator hose :) oh well. I'm thinking the deck of this block is warped. 3rd headgasket and I only connected up the turbo last night and only 7psi so meh.
I like burnouts.
iViLe
Post by iViLe »
Stock 9.1 comp short block, I also Remapped the ignition table for "boost".
Stock boost 7psi. Cooler not mounted cos im too lazy atm to order silicone hoses.
Thrashed it till the tyres blew and the temp guage hardly budged, unlike before.
I like burnouts.
clint
Post by clint »
....thats wicked :!: the "whip" that comes from doing donuts actually looks violent.....hope your straped in :wink:
ONE SHALL STAND, ONE SHALL FALL....
stockgemils1
Post by stockgemils1 »
thats pretty cool bro goes good hey.did you have to modify the steering to get the donk in
iViLe
Post by iViLe »
Nup, only had to move the battery and cut a new hole for the shifter.
I like burnouts.
stockgemils1
so the later model steering colom must be diferant with the nuckle at the top i just fitted a ls1 in my te and im just f*#cking round with the steering as it is touching on the starter slightly thanx mate
DryftKult
Post by DryftKult »
later column has a unijoint, early model doesn't
iViLe
Post by iViLe »
stockgemils1
I did rotate the starter motor slightly so the solenoid on it would clear, you might have to buy an adjustable one.
I like burnouts.
