Cam's TX Gemini drag car TXPSI by Gemracing new pics page 15
The car also made max power at 8000rpm,and max torque was 7700rpm......TUFFTG wrote:So just an update.....
Had the Gem on the dyno yesterday and on our "low boost" setting of 28psi (no nitros at this stage) we made a healthy 304.9kw!
We will go back on the dyno next week to make a few adjustments and set "high boost" which will be another 10psi and that should bring another 100kw to the figure!
Happy days ahead
Big thanks to Darren @ Gem Racing he definately knows how to build these things strong!
Cam.......
I'm more than confident this will see the power we need to run into the 8's......Once it runs an 8 we'll gas it the whole pass,but Id say for now we'll just use it to spool the turbo....
And the best bit,its running E85 from United servo,not bad for $1.40 per ltr...........
Darren
Current Car.....
-G180 TX red coupe 9.20@148.6mph on a 26x8.5" tyre and no nitrous 2380lbs with driver
Re: tx
We had it on the dyno a few weeks back could only get 35psi boost,the pic below is what it made...fatTG-TE wrote:Any updates.pics on how this things going
Since then Ive changed the spring in the wastegate to one that should give us 45psi boost......
It wont be long before this is out racing,Cam just needs to fit the front and rear screens and fit the parachute....Once that's done we'll go back on the dyno.....
I'm still more than confident this car will run in the 8's once its done.....Ive also wired the nitrous to turn off at 20psi,don't think we'll use it all the way just yet.......
Darren
Current Car.....
Got all the lights in, screens will be fitted Wednesday and then I'll order the chute.... Will take pics later in the week of the finished product now I have it back.... can't wait
** 1983 ZZ/Z Gemini
** 1975 TX Gemini coupe
**Gem Racing TX Drag Car 347rwkw G180 EFI Intercooled Turbo plus Nitros built for 8's
Any updates on yours?Todd wrote:Wow, well done Cam and Darren.
maybe we should make a day of it when mines finished
I'll put up some of the other pics I took over the weekend the makeover has come out awesome! Can't wait to get it out and big thanks to Darren for his magic on this one!
** 1983 ZZ/Z Gemini
