Encyclopedia Ronnie's pre adr TX coupe
Gem WRC
Post by Gem WRC »
haha. That's seen better days that one! :shock:
No wonder you can't see straight at 80km/h
Encyclopedia Ronnie
Post by Encyclopedia Ronnie »
Gem WRC wrote:haha. That's seen better days that one! :shock:
yeah she was a lil bit worse for wear,
oh and NO its not painted yet
Encyclopedia Ronnie
no more rego :cry: :cry: :cry:
Encyclopedia Ronnie
so su593m had a few left gaurds for sale, figured i would grab them for teh coupe in hope it would motivate me to paint it, funnily enough the gard im gonna use was off my old tc!!! was the best panel of the whole bloudy car anyhow it had to dents in the front corner 1 was probably about half a glof ball the other about teh smae butr more oval shaped, none theless with a bit of love heat and a nice filing the gaurd looks much beter,
its had a small repair at the bottom corner that whilst done well im going to chnage for a flush join and i will tig the repair to avoid warping the panel anyhow pics
i smashed some etch primer on.... umm a lil thick, its a gem we cant be to safe lol
annnnnnnnnnnndddddddddddddddddd a random pic
Encyclopedia Ronnie
Re: Encyclopedia Ronnie's pre adr TX coupe
so this thing ended up getting some more love, the standard cam gear got the boot and an adjustable 1 found its way in there, the weber finally decided it needed a rebuild and along with it came a holley blue, reg and port matched manifold to adaptor,
now it would seem theres a set of twin 36 idfs on there way just need a manifold and to make a new exaust and i might consider sending it to the dyno
ajs991
Post by ajs991 »
But is it painted yet? :lol:
List of people I hate: You.
Encyclopedia Ronnie
com on andy what kinda question was that....... of course not lol, when i find a drivers gaurd and bootlid to go with my bonnet and left gaurd then i will paint it maybe
Encyclopedia Ronnie
so with the car really starting to feel neglected recently elky sent me this little piece of early model gold
with this now aded to the left gaurd and bonet im just needing a bootlid now.
so the 32/36 weber that was on theer was really getting tired, it was a bit rough when i bought it and the acelerator pump was starting to leak so i though a rebuild would do it a world of good
on a whole turned out beter than i thought, while i was there i thought the manifold could do with a tweak as well sooooo.......
this pretty much left me thinking if the manifolds done and the carbs done i beter get some fuel to it properly which ment a new pump reg and a few mods to go with
so with some of this
and a bitta this
i had something like this
then i took the resister out of the fuel pump circuit and put a extra fuse inline to run it off the standard fuel pump circuit at full 12v, best mod i ever did as far as practicallity and saftey, the old pump driven off the number plate light was a bit povo
and finally i decided to give my cam abit more agression with the adtition of this beautifull cam gear,
now this was all good till the extra load streched the timing chain to the poiunt it was gonna break, so that ment a new chain had to be put in and after about an hr or so i had a new chain in there retimed and back firing on top, the gear has no timing marks on it so u use the crank to adjust advance or retard
so basically i now sit at lights with a lumpy as f*#k idle with people confused as f*#k when i tell them standard motor lol,
and other than that for being diven daily its doing a OK (touch wood)
Encyclopedia Ronnie
because you can never have to many early model parts about lol
GEMWRC
Post by GEMWRC »
Top stuff .. Good to see it getting some love
Encyclopedia Ronnie
and guess what its stuill not painted although i did prang it again :(
DrewZa86
Post by DrewZa86 »
Encyclopedia Ronnie wrote:and guess what its stuill not painted although i did prang it again :(
Hopefully nothing too serious man?
Again since recently?
Encyclopedia Ronnie
still own car, still not painted, still has same engine maybe some day soon ill fix it up,
Encyclopedia Ronnie wrote:still own car, still not painted, still has same engine maybe some day soon ill fix it up,
Get going man! Also....how many f*#cking gaurds do you want :lol:
Nick-
