TD Coupe Twin Cam Rally Car
Phil
Re: 84 TG Rally Car Project
Post by Phil »
Ahhh car part porn :D
I take it your staying PRC, Do they allow for more mods in AMSAG
Gem WRC
Post by Gem WRC »
Yeah PRC still, it's under CAMS so you qualify
for many more events.
AMSAG is good & has more freedom in regards
to engines, but suspension mods are similar to
PRC still.
GEMWRC
Post by GEMWRC »
That flywheel!!!
I just browsed the Jun website for 30 mins.. That place is awesome.
How much they do they charge for cams ?
Gem WRC
Post by Gem WRC »
Yeah I just want to mount it on the wall
& look at it!!!
The cams I got made where re-profile std
cams, as no one makes new blanks.
The cam profiles where developed with JUN
Auto & my mate in Japan. So they aren't an
'off the shelf' item.
They where around $1200 plus the AUD$ is
shithouse now anyway
Gem WRC
Post by Gem WRC »
New CP pistons have arrived, bottom end can
now begin :)
Old vs New
Compression ratio of 11.0:1, so more piston up top.
A fair old weight saving too (not including the rings & bearings)
GEMWRC
Post by GEMWRC »
Wow thats awesome .
I want this , merry xmas ..
Do you know if CP have the combustion chamber shapes on file for G180w ?
Gem WRC
Post by Gem WRC »
Merry Xmas mate ,
Yep CP have everything you need to get
pistons made for a g180W. They had never
made pistons for a G200W before. They
needed a sample & had to adjust some things
on the G180W measurements.
RALLYGEM
Post by RALLYGEM »
Hey mate sort of cost are the pistons and rods . Are they oversize . And can you give me a contact at CP.
cheers Ian
Gem WRC
Post by Gem WRC »
Yeah the pistons are 87.5mm, 0.5mm oversize.
They where made to my specs & around $1300.
The only conrods that are a direct replacement
for the G200W are the Spool conrods.
I used Carrillo Toyota conrods & they where $1300
too.
I went direct to CP, but SPOOL Imports have done
quite a few CP Pistons for G180W & have all of the
drawings for them.
Gem WRC
Post by Gem WRC »
New intake trumpets turned up this week. 50mm long billet aluminium.
Cylinder head is now complete ready to go, Camshafts, valves, springs, etc
Holden202T
Post by Holden202T »
all looks nice :)
x2!
Getting close now!
What are you going to do on the ignition side of things, or did i miss it somewhere?
Josh
Post by Josh »
Carby porn! Loving it!
Gem WRC
Post by Gem WRC »
With the ignition I think I will look at a SOHC 'G' series
dizzy or a Nissan Pulsar one to make fit.
Then I will run the MSD 6AL2 unit with the optical pickup
in the dizzy as what was on the old G200 SOHC.
It worked very well & had not one issue with it.
