Javi's Drift Gemini
Re: Javi's Drift Gemini
As it turns out, making a delco do closed loop boost control isn't very easy. So instead, I did some skids.
troyrotor wrote:ozgem classifieds - for all your mowing needs
- Holden202T
good compromise lol
Went out to Raleigh to compete and managed to come home with second place. I'm cheerin'. The battle for first starts at 3:00
Best f*#cking vid on ozgem so far hands down!
Thoroughly enjoyed that. Fantastic driving dude
Top effort. Engine sounds so much better now!
Any idea how much castor you are running up front?
- Holden202T
that's some hectic wheel work and up and down the gears! nice work with second place!
Thanks! I've been working hard at it and I'm hoping to start tangling with the Raleigh pros next year.DR_GEM wrote:Best f*#cking vid on ozgem so far hands down!
The front end is mostly standard, with some slip on lock spacers, Koni yellows, and king spring superlows. Standard castor, camber is just maxxed out on the upper ball joint (not slotted yet. I have things in the works for that), and standard swaybar.F3ARED wrote:Top effort. Engine sounds so much better now!
Thank you! I really want to get a 3.7 or a 4.1 in there so I don't need to dance through the gears as much, but the gemini diff is a bit restrictive as far as ratio choice...Holden202T wrote:that's some hectic wheel work and up and down the gears! nice work with second place!
PS If you have done anything with a MAC solenoid on delco I'm interested to see what you came up with.
Diesel gearbox and or diff would fix that....
Silly question, the diesel center (read: not including crown wheel) and the petrol center, are they different? I have a romac spool here and if I could put the diesel crown wheel on it I'd be laughing.F3ARED wrote:Diesel gearbox and or diff would fix that....
Yep unfortunately differentJavi wrote:Silly question, the diesel center (read: not including crown wheel) and the petrol center, are they different? I have a romac spool here and if I could put the diesel crown wheel on it I'd be laughing.F3ARED wrote:Diesel gearbox and or diff would fix that....
Much more akin to the piazza LSD centre - crown wheel's not interchangeable unfortunately otherwise I would've done it for my setup
Went out to Archerfield and put my car into a wall. Also did a few skids while I was there.
- Holden202T
No not yet, but VL400 is I think, I'm waiting for his results, and also building the car/motor for use with it still!Javi wrote:Thank you! I really want to get a 3.7 or a 4.1 in there so I don't need to dance through the gears as much, but the gemini diff is a bit restrictive as far as ratio choice...Holden202T wrote:that's some hectic wheel work and up and down the gears! nice work with second place!
I said 'f*#k it' and bought a standalone boost controller for it. Maybe one day I'll have it working on delco, but that won't be today hahaHolden202T wrote:No not yet, but VL400 is I think, I'm waiting for his results, and also building the car/motor for use with it still!Javi wrote:Thank you! I really want to get a 3.7 or a 4.1 in there so I don't need to dance through the gears as much, but the gemini diff is a bit restrictive as far as ratio choice...Holden202T wrote:that's some hectic wheel work and up and down the gears! nice work with second place!
- Holden202T
as long as it works all good
It was quite wet this weekend. I need some wider tyres so I can get some grip! It was like drifting in slowmo.
The new head sounds good though, just a bit of a shame that I didn't get to see if it went any faster haha
