jimmymeik89s EFI Turbo TX to be..
- jimmymeik89
FOR TURBO UPDATES GO TO LAST FEW PAGES
Hey guys,
After being out of the Gemini game for nearly 2 years as i crashed my TE in 2012 im back with a 75 TX base model!
G161
4 speed.
Full black vinyl interior
Absinthe Yellow factory paint
15' interceptors powdercoated silver w/whitewalls
Pedders front swaybar
50mm Kingsprings
new ball joints/tie rod ends, boots, upper and lower arm bushes
H4 round headlights
Rust removed from front guards and boxes, speaker holes welded up.
Towbar
since ive got my hands on it i have spent alot of time in the garage getting her back up to spec.
Things that i have done so far:
- Sikaflexd the torque tube rubber
- New diff oil
- New gearbox oil
- Fixed interior light
- Timed and tuned
- Removed doorbanners
- Full detail inside out including engine bay
- Installed a head unit and speakers ontop of parcel shelf
- Installed an overflow bottle
- Installed Fire extinguisher under front of passengers seat
- Wired triple gauges vac/oil/volts in gear console
- Installed digital water temp gauge
- Extra spacers for rocker bolts as was leaking oil
- bled brakes
- New wipers
- Cleaned up wiring (alot to go)
- Put Gem on club reg
- New gearknob
also came with the sale was a G161 that is being rebuilt shortly (already pulled down)
got alot planned but will update as i go.
Heres some photos for y'all!
THE DAY I PICKED IT UP:
GETTING STARTED ON TT RUBBER AMONGST OTHER THINGS
IT WAS f*#cked!!
AFTER A DETAIL:
INTERIOR PICS:
CLEAN BOOT:
OUT & ABOUT:
Hey guys,
G161
4 speed.
50mm Kingsprings
H4 round headlights
Towbar
- New diff oil
- New gearbox oil
- Timed and tuned
- bled brakes
- New wipers
- New gearknob
IT WAS f*#cked!!
AFTER A DETAIL:
INTERIOR PICS:
CLEAN BOOT:
OUT & ABOUT:
NEW 75 TX TURBO http://www.ozgemini.com/forums/non-tech ... =6&t=47619
OLD TE SL/X SEDAN :'( http://www.ozgemini.com/forums/non-tech ... p?p=422309
S.E VIC Cruise Club http://ozgemini.com/forums/non-tech/vie ... hp?t=44328
Re: Jimmymeik89 - The new TX!
Way to go . Thats a good crew of Gems
yeah darren we had 25 or something like that
was a good turn out
ben did a good job organising it once again
there was even a rs import there as well
was a good turn out
looks good man love it! did you get the rims powder coated? im getting mine done soon, if so what did they charge? just after a rough idea of what its worth. cheers
- jimmymeik89
Thanksrotagem wrote:looks good man love it! did you get the rims powder coated? im getting mine done soon, if so what did they charge? just after a rough idea of what its worth. cheers
They were already done by previous owner.
Pretty much they were sand blasted then powdercoated, he then got new hubs and had them machined to fit the rims, then new tyres and white walls think he spent in excess of $1k including the rims.
yeah true. mine are already blasted and machined just ready for powder coating. cheers
So glad to see you back Jimmy!!!!!!!!
- jimmymeik89
so ive been doing a fair amount of work on the gem lately.
since last update i have done the following:
Service with Penrite HPR30
Leather gear boot
Slotted and Dimpled rotors
Bendix Ultimate pads
Heavy Duty Clutch
Underbay bash plate
Last month i went to Heathcote Drags with the gem and did best of 18.8@70mph with a 2.2 60 foot
Heres some photos for your enjoyment:
Epic single pegger!
BASHPLATE
Leather gear boot
Heavy Duty Clutch
Underbay bash plate
Epic single pegger!
BASHPLATE
- jimmymeik89
Re: jimmymeik89s Turbo TX
I am now rebuilding the TX
So far i have done:
Fuel system including of surge tank, 070 pump, EFI Filter, new EFI hose, FPR
G161 is out getting a mild rebuild with dished pistons, moly rings, mild cam, hd valve springs etc
attached all the turbo gear to eachother ready to be bolted to the motor when its back.
cleaned the engnine bay and am rubbing down areas currently for touchups
going blowthrough so have all the weber gear on the manifold ready to be bolted on.
waiting for the motor now then bolt it all together. getting it to the exhaust shop then straight to the dyno to be tuned
here are some pics of dummy fittings and other things:
So far i have done:
s*#t your move fast !
- jimmymeik89
yeh mate. Haha want it done for summer cruising. Ive sourced a LSD which will go in after its tuned then more driveline reinforcing. Cant wait!GEMWRC wrote:s*#t your move fast !
looks killer man but that turbo looks f*#cking huge what size is it?
its not leaking oil its sweating power
- jimmymeik89
I know i told you on FB.Sweeney wrote:looks killer man but that turbo looks f*#cking huge what size is it?
But for the rest its same size as a GT3076 apparently. but with a smaller rear housing for better spool. will be laggy but i dont mind.
Excellent.
- jimmymeik89
so tomorrow is paint day. hopefully all goes well as i havent used a air feed gun before. here are some photos for your fapjoyment
