TC Gemini Coupe
Re: TC Gemini Coupe
Battery tray removed, 40+ holes welded up, wiring tabs removed, abit of nikki here & there. . . . . . . .
High Fill !!!!
High Fill !!!!
- Attachments
- hf1.jpg (192.16 KiB) Viewed 6608 times
- hf2.jpg (180.97 KiB) Viewed 6608 times
Build thread- viewtopic.php?t=48434 - TC Coupe Project - LH Torana - D22 Navara.
Pics or it didn't happen
Re: TC Gemini Coupe
Neat!
Re: TC Gemini Coupe
Good stuff
Re: TC Gemini Coupe
More High Filling.
- Attachments
- nose cone.jpg (97.53 KiB) Viewed 6530 times
- guards2.jpg (139.8 KiB) Viewed 6530 times
Re: TC Gemini Coupe
Inside of the bonnet dings filled, all rubbed back, & high filled.
- Attachments
- Bonnet inside.jpg (262.63 KiB) Viewed 6484 times
Re: TC Gemini Coupe
ohh yeaahhhh
Re: TC Gemini Coupe
I have go the outside of the bonnet in high fill, & revisited the doors - test fitted them about 5x times, stripped them out, welded up a few holes that snuck up, drilled out the mirror holes, & have high filled them inside & out.
- Attachments
- 20171116_072416.jpg (179.7 KiB) Viewed 6339 times
- 20171104_154442.jpg (103.54 KiB) Viewed 6339 times
- 20171116_072443.jpg (129.8 KiB) Viewed 6339 times
Re: TC Gemini Coupe
It's getting there!
Re: TC Gemini Coupe
Downhill stretch now mate. You going Clear over base or just solid?
Re: TC Gemini Coupe
The plan is clear over base, trying my best LOL.F3ARED wrote:Downhill stretch now mate. You going Clear over base or just solid?
Next I will rub & paint the door jams, so I wanted to knock over this job on the L/H Quarter window Pillar before I start that area.
- Attachments
- Qwindow1.jpg (99.7 KiB) Viewed 6289 times
- Qwindow2.jpg (97.2 KiB) Viewed 6289 times
Re: TC Gemini Coupe
A quick welding job that took more than a few goes to get to a point that i'm happy with.
- Attachments
- drip rail 1.jpg (165.38 KiB) Viewed 6219 times
Re: TC Gemini Coupe
And onto the other side, this one was above the quarter coupe window.
- Attachments
- drip rail 2.jpg (150.29 KiB) Viewed 6202 times
Re: TC Gemini Coupe
Door Jams in high fill.
- Attachments
- Door jams.jpg (124.52 KiB) Viewed 6146 times
Re: TC Gemini Coupe
So then this happened . . . . . . . .
I ordered paint from the I.D Tag, just gave the guy the code for the factory Mandarin Red.
Decided to go 2K Solid, & I put down a coat of isolator first - I didn't want to risk any fry-ups.
I finally have some colour down !!!!
- Attachments
- Bonnet Isolator.jpg (76.19 KiB) Viewed 5950 times
- Bonnet Mandarin.jpg (68.48 KiB) Viewed 5950 times
Re: TC Gemini Coupe
Nice!
You'll make Geminats Easy
