TC Gemini Coupe
Re: TC Gemini Coupe
When you hope theres no rust, and you think there's no more rust, and you pack your welder away ........
Theres Rust!
a few little spots, drivers side front windscreen bottom.
Theres Rust!
- Attachments
- gemrust.jpg (203.01 KiB) Viewed 13999 times
Build thread- viewtopic.php?t=48434 - TC Coupe Project - LH Torana - D22 Navara.
Pics or it didn't happen
Re: TC Gemini Coupe
That ones fixed.
- Attachments
- front screen rust.jpg (64.76 KiB) Viewed 14395 times
Re: TC Gemini Coupe
Not sure how the left vent even attaches, mine was silicone'd on, so I drilled & glued in some socket head cap screws, and repaired some broken bits on both left hand vent & drivers side fuel cover flap.
- Attachments
- left flap2.jpg (44.66 KiB) Viewed 14394 times
- left flap.jpg (49.78 KiB) Viewed 14394 times
- flaps.jpg (104.83 KiB) Viewed 14394 times
Re: TC Gemini Coupe
The fun bit with this mod is getting all 4 nuts and washers on. Can be done.
Re: TC Gemini Coupe
Everything lined up, high filled, guide coated, and ready to block!!!
hopefully it wont need another primer hit and I can get this thing into a booth to put some paint on!!!
- Attachments
- 20190316_1735102.jpg (203.52 KiB) Viewed 14269 times
Re: TC Gemini Coupe
get it painted! Looking forward to cruising with this at nats.
PS mind telling me about the mod to fit the vent a bit?
I'm going to yolo the only one I have and see if I can get it to work
Re: TC Gemini Coupe
So all I did was drill some holes in the passenger side flap- a little bit deeper,where the snapped off lugs were meant to go, and glued in some stainless M5 Socket head cap screws (allen key bolts) then had to drill the holes in the body out just a little bit.
once the car all goes together, it will get nuts put on behind.
Not 100% but should be accessible from both boot behind wheel arch, & rear coupe trim access area in front of wheel arch.
An old bloke I know told me they used to prank their mates and pretend to open the fuel door but rip the passenger side off as a joke.
- Attachments
- FLAP.jpeg (231.06 KiB) Viewed 14249 times
Re: TC Gemini Coupe
Ok cool thanks.
I've got a NOS one I found but I don't want to use it in slim to none chance it ever gets rotisseried and restored.
I might have a play with the busted one I've got and see if I can get it to fit and see how I go about locking it off.
Appreciate that
Appreciate that
Re: TC Gemini Coupe
Aaaaaaaaaaaaaaaaand . . . . .
The blocking begins / Continues.
By the way, i'm not a penal beater, so this is going to take ages.
- Attachments
- Resized_20190323_181933[4501].jpeg (145.36 KiB) Viewed 14226 times
Re: TC Gemini Coupe
A penal beater would make you a prostitute wouldnt it?
Re: TC Gemini Coupe
A small update,
Plenty of blocking back high fill, and now the boot jam is painted.
next boot lid goes on, and the final rub down, and paint time.
- Attachments
- bj.jpg (181.64 KiB) Viewed 13943 times
Re: TC Gemini Coupe
HAHAHAHAF3ARED wrote:A penal beater would make you a prostitute wouldnt it?
Funny Typo.
Re: TC Gemini Coupe
So this happened!
- Attachments
- 13072.jpg (193.21 KiB) Viewed 13776 times
- 13073.jpg (182.77 KiB) Viewed 13776 times
- 13074.jpg (238.97 KiB) Viewed 13776 times
Re: TC Gemini Coupe
masked up.
- Attachments
- 1307.jpg (110.19 KiB) Viewed 13775 times
Re: TC Gemini Coupe
Oh man that looks excellent
