Re: Redtop C20XE Gemini
- New Member
Ive been posting some of me pics etc on the Gemini chat page as some of you that has been looking so ive finally got on to putting a build thread bit late now but ill start where im up to now and if anyone wants any other information or pics ill see what i can get out of me phone from th earlyer stages of the build.
This i where i am up to now just putting the intake on now and putting fuel lines together, looking at moving the fuel regulator now from its current position to make room for a ice box for the air intake heat exchanger going to cut and fold up the box tomorrow and tig it up.
- Attachments
- 20170805_111323.jpg (711.05 KiB) Viewed 9192 times
- 20170805_111315.jpg (844.52 KiB) Viewed 9192 times
Re: Re: Redtop C20XE Gemini
Are you racing this thing or is it a street car?
Great to see a build thread
- New Member
It will be street registered and used for race when i have time to do so but when things start to get a bit hard to keep registered it will be more race purpose only.
Done some more today moved the fuel regulator made the ice box for the intercooler and bolted up and done some of the plumbing for it. But heres a pic of a bit more progress.
- Attachments
- 20170808_150137.jpg (748.7 KiB) Viewed 9174 times
- 20170808_173001.jpg (825.58 KiB) Viewed 9174 times
- New Member
Re: Re: Wiley's Redtop C20XE Gemini
Well thats it for this week, till late next week then im on holidays for 3 weeks si hopefully ill.have it running over that 3 weeks.
So what ive done today is me intercooler pipping and some other little stuff , ive had to modify a few little things slightly along the way from my original fit of the dumby i had to measure things up but were only minor things but algood and on the way to hopefully have ir running in the next few weeks will keep you posted.
Cheers Wiley
Cheers Wiley
- Attachments
- 20170809_102648.jpg (828.99 KiB) Viewed 9160 times
- 20170809_102640.jpg (887.59 KiB) Viewed 9160 times
- 20170809_102631.jpg (890.63 KiB) Viewed 9160 times
far out , this looks serious
Hi Glenn, what engine mounts did you use? Sump? Gearbox setup? Cheers!
- New Member
I used the standard gemini mounts, just built a guset that was engineered to weld onto the front of the cross member but still uses the very front bolt hole on the original Cross member and a new one in the guset that was welded on x member just to bring the engine foward so the engine would fit in with modification to the fire wall. The sump i custom made me self cause the C20XE engine is quite high i did look at other sumps like the manta, and the C22ne engine in the rodeo but were still to high so hence i built me own, and the gearbox i just the used the 5 speed out of the C22ne rodeo gearbox just to get it running for now till i break it then ill look at putting something better in it i did slightly modified the mounts for the gearbox but nothing to major that still could use the original gearbox mount bolt holes i did convert it back to cable clutch as well form the original hydraulic clutch in the rodeo.
- Attachments
- 20170626_125934.jpg (825.3 KiB) Viewed 9128 times
- New Member
Some of the other pics i have are to big to load private msg me if you want Coxy.
- Attachments
- 20161003_111743.jpg (783.46 KiB) Viewed 9126 times
Ah wicked! I actually have a C22NE rodeo at work with a holde piston, i'm trying to work out if I want to fix it or raid it for 20XE conversion parts.. Tempted to do one NA one day. Did you get yours from Lee? I remember he had a Calibra for a while that he bought just for the motor. But he went Ecotec crate motor for the drag car. What head does yours have? The Coscast type or later one?
- New Member
Did you want to sell the gearbox from the c22ne coxy lol.
Na i did do a fair bit work down at lees but i got all me own engines i do have a couple of the costcast heads and a couple of the others in my collection .
How did you get everything? Private import from the uk?
- New Member
Ya most of it was either from uk or the us i got a few internal engine things from in Australia witch didn't cost really any more then getting custom stuff made here for the G series engine. cause over there there just like buy it of the shelf already done and the postage wasn't a real big issue cause some of the stuff came quicker in the mail from over there then getting s*#t sent locally to me here in Australia.
- New Member
I got all me engines here in Australia just from calibra wrecks or Wreckers.
Ah ok cool.
