My new daily [i change em often dont i?]
I think ill let the pics do the talking, im sure we can work out what it is
Woo, bit of an update, been doing things here and there. When i bought the car it was standard bar the A`pexi cat back exhaust and air filter, came with a Hybrid front mount cooler kit not fitted.
Fitted 17" x 8 and 17" x 9 Doritek Beer R racing copies, with cheap rubber [that works suprisingly well at the strip, see below].
Front mount was fitted, car went pretty good until i f*#cked the rubber bush/dampener in the dual mass flywheel and caused the clutch to start slipping. Now has a HD Daiken clutch and single mass flyweel [courtesy of Aaron, thanks buddy ], fitted a Split dump pipe and front pipe, high flow cat. Car got dyno'd on Saturday @ PET where it made 178rwkw on 14psi, with alot more mid range then it previously made. Still waiting on the printout.
So then it was off to heathcote raceway to lay down some numbers. Was hoping for a 13.2 but had a few dramas early on. Best pass was a 13.5 when the cooler piping started leaking, back to the pits, fiddled with it a bit and went back out.
After running consistantly in the 13.4-13.6 bracket with 2.05X - 2.09X 60ft times, cracked the s*)ts and decided to be brutal on the last two runs.
First of the last two was a 6500rpm clutch slip off the handbrake which netted a 2.03 60ft and a 13.33@105mph. Back to line up again, Zok [good mate] told me give it hell.
Last run was a 7200rpm slip off the handbrake launch, 2flat 60ft [on street 17" tyres remember!] and netted a 13.29 @ 107mph. Job done. A mate with an S14A making 205rwkw only managed 13.27@107mph [prick beat me by .02!] so i was pretty happy with the time. Should have more pics + vids of the runs later tonight.
My gtr rims look better than your GTR rims.
http://img512.imageshack.us/my.php?imag ... tl3.th.jpg[/img]
http://img171.imageshack.us/my.php?imag ... sh7.th.jpg[/img]
http://img147.imageshack.us/my.php?imag ... qu1.th.jpg[/img]
http://img147.imageshack.us/my.php?imag ... ku2.th.jpg[/img]
And a special one Closed road of course
http://img529.imageshack.us/my.php?imag ... zp4.th.jpg[/img]
(Links are full size)
Welcome to the fun side
Another Quality Post by Crumz
Fix the roads, not the fines.
