It is currently Sat May 30, 2020 7:03 am
Post new topic Reply to topic  [ 18 posts ]  Go to page 1, 2  Next
 Post subject: The Postie
PostPosted: Sun Apr 04, 2010 4:45 pm
thought id throw some pics up of my postie. shes had quite a few modifications they include:
khaki green paint job
renthal handle bars
chrome mirrors
slim line indicators
bigger fuel jet
air box removed
uni filter foam pod
thumpstar exhaust
chopped rear fender
chopped seat pan
retrimmed seat
17 tooth front sprocket
and in this photo i have a Lifan 140cc motor with oil cooler. the day i got it regoed i cooked the motor so it needs a freshen up.
PostPosted: Thu Apr 15, 2010 8:13 pm
well a bit of an exciting update.
bought a little turbo for this so im gonna have a go at forced induction. so far ive sorted a location for oil feed. will need to drill into a gallery in the head and tap an earl fitting in. for the return it will be plumbed into the oil fill location.
as for fuel ive mounted an ammunition box where the air box used to be so im going to mount an external fuel pump and regulator in there.
other then that i just need to plumb it all up.
will post pics tomorrow.
any moto heads have suggestions for fuel pump. im guessing the boost levels wont be over 6 or 7 psi so will only need 7psi pump.
PostPosted: Fri Apr 16, 2010 9:51 pm
Better idea just put boost pressure into the fueltank via a small hose this means that fuell will still flow into carb as normal.
Lots easier than trying to run all the fuel pump stuff
You will have to make the fuel tank airtight though so it holds pressure
PostPosted: Fri Apr 16, 2010 10:41 pm
hmm, if the fuel was low say 1/4 of a tank thats 4ltrs of air the turbo needs to pump in there before its a boost pressure. wouldnt it just create lag.
PostPosted: Thu May 20, 2010 2:34 pm
hi mate i already turbod a postie used a suzuki capacino turbo on alki and a sneaky pete 25hp shot of gas you dont need to run a fuel pump. i put the carb in front of the turbo and drilled the jets out i think the main i drilled 1.5mm and the idle .8mm for methonol and 1mm main for petrol.it made 6psi boost and 10psi on the gas i have some pics of it somewhere ill try and find them
PostPosted: Thu May 20, 2010 5:54 pm
pics would be awesome. i was thinking drawthrough. ill post pics of my turbo soon. where did you plumb your oil from?
PostPosted: Fri May 21, 2010 6:22 pm
i didnt plumb it i gravity feed the oil using thin oil it wasnt very eficent but it worked it was very funny passing traffic at 130 on a postie.i really liked it the best with just the nitrous and the methanol i would hit that thing everywere use a full size car bottle in one arvo mounted on the rack lol
PostPosted: Fri May 21, 2010 6:55 pm
what do you mean gravity feed the oil?
PostPosted: Fri May 21, 2010 7:17 pm
i got a brake fluid remote style resivare mad spella ha ha mounted higher than the turbo not a good way to do it but it did stop it seizing when we were playing round with it.if it was permanant i would have taped into the galarie like you are going to
PostPosted: Mon May 31, 2010 8:39 pm
this is kinda inspiring for me to do it to my pitty haha
t3/t4 haltech powered forged 4ze1 gemini in the build
PostPosted: Tue Jun 01, 2010 12:11 am
how do you go about dealing with a boosted crank case? would it not slow/stop the piston from coming down on power stroke?
PostPosted: Thu Jun 03, 2010 9:40 pm
how will the crank case be boosted?
PostPosted: Fri Jun 04, 2010 9:00 pm
some engines have the air/fuel mixture run through them into the cylinder..
Tezza is the bike man.. he'll be able to fully answer the question
PostPosted: Fri Jun 04, 2010 9:16 pm
that's only 2stroke isn't it? well honda 110s are a ohc with the intake going into the head.
PostPosted: Mon Apr 29, 2013 6:23 pm
any photos of the turbo set up?
