Ye Royal Shed
This Forum is here for Members to post pictures of interest. DO NOT post porn. If we see muff action will be taken towards the member. This is an open site to all ages and also have members using it from work locations. Keep it clean. If the picture is slightly not work safe, post CLEARLY in the topic heading NOT WORK SAFE
LOK15
Post by LOK15 »
had help today with the roof sheets , 3m is a little too much for 1 guy to handle
half is done now , and maybe during week other half will be done , then back wall , then the plaster!!! then paint!!!!!!!!
Gromet
Post by Gromet »
Its coming along nicly lok, heaps more done from when I saw it.
TFHOON
Post by TFHOON »
Hey Lokie , are you sure the pink bats will make the shed cooler cause when i had pink bats put in the roof of my house it made it hotter.
LOK15
Post by LOK15 »
TFHOON wrote:Hey Lokie , are you sure the pink bats will make the shed cooler cause when i had pink bats put in the roof of my house it made it hotter.
there is a BIG difference in temp already inside , but i can feel the heat radiating off the roller doors , so im planning to get this
which i'll glue/sika to the inside of the rollerdoor to reflect most of the heat away.
the roof has whirly birds in it , which allows the built up hot air to escape , and i have left air gaps at the base of the styrofoam on the walls to allow the cooler air to pass up the walls into the roof
Andrew64
Post by Andrew64 »
update???????????????????????????????
Image ©2009
Gromet
Post by Gromet »
Andrew64 wrote:update???????????????????????????????
X2
LOK15
Post by LOK15 »
update.
walls have been plastered and painted.. roof is not being finished off at this point , but walls have had 2 coats of paint and now have shelves agaINST THEM and stuff is starting to be stored on them
Locked
