It is currently Mon Aug 10, 2020 3:34 am
Post new topic Reply to topic  [ 308 posts ]  Go to page Previous  1 ... 17, 18, 19, 20, 21  Next
PostPosted: Tue Mar 12, 2013 10:10 am
Update time, looking at a bond roll bars 6 point kit, gotta get it in under the old rules before they are phased out on the 1st of april.
I'll fit it up then I have a fabricator that used to work for 888 lined up to weld it for me :)
If your car isn't cut (ie tubs etc) then you can have a bolt in cage tech'd by andra down to 9.00 with bolt in intrusion bars :)
I will be running the cage through the dash, which I will be making a fibreglass or carbon copy of then padding for adr's.
Going to try & get a street legal 9 second car done, wish me luck!
Last edited by redzone (coxy) on Fri Mar 22, 2013 11:18 pm, edited 1 time in total.
PostPosted: Tue Mar 12, 2013 12:08 pm
Good luck man.....carbon fibre adr approved dash sounds like a nice addition :-)
PostPosted: Fri Mar 22, 2013 11:17 pm
Got another set of Simmons OM16's a while back from a Golf, they are "supertourer" spec with 1 inch outers :lol:
Scored a pair of 2.5 inch outers, and another pair of 3 inch outers from ebay recently, so i can turn them into dishy 7.5's and 8.5's..
Stripped the interior out the other day ready for the cage, the kit only turned up today..
PostPosted: Sat Mar 23, 2013 12:40 am
is that a M&W ignition box in frnt of the gearstick??
PostPosted: Sat Mar 23, 2013 7:59 am
Yep it's a pro14, now my number 1 suspect for causing my ignition misfire..
PostPosted: Sat Mar 23, 2013 9:55 am
Time for a MSD DIS-4 HO :wink: :wink:
haha nah stay with CDI ignition its a lot better for Hi boost has better amperage or voltage than the other setup, im confused at this point in time just woke up,
I can verify later in the day if you'd like, but you probably already know...
PostPosted: Mon Mar 25, 2013 9:55 pm
coxy what shifter are you smugling under there?
PostPosted: Mon Mar 25, 2013 10:44 pm
Stock MUA remote shifter bud. You just reminded me, i have 2 non ZZR remote shifters i have to advertise...
PostPosted: Mon Mar 25, 2013 11:20 pm
quite nice i must say, i miss my piazza shifter lol
 Post subject: Re: My green TX coupe, 4ZD1T 422rwhp vids page 15
PostPosted: Tue Oct 01, 2013 11:18 pm
Update!
Cage is done, pics soon. Guy who did it used to work for 888 building V8 supercars so his tig work is amazing. While the interior was all out i took the time to retrim the interior, well other than the seats and doortrims which will be done soon. Oh and carpet lol. Got her ready to race for Jambo and had an ok weekend running high 11's to 12's with the plugs gapped down, yeah she still had that misfire issue. I had sent the M&W away to get some green terminals replaced and get it checked while the cage was being done. Didnt make any difference to the misfire.
Had a good chat with Smokey at Jambo comparing notes on misfiring Gemini's and we got to talking about Piazza alternators and whether they are up to the task with big pumps and well, big everything. So since Jambo i have been investigating fitting a larger alternator. My mate at VPW and my auto sparky couldnt come up with anything that would fit easily, but my sparky did say i should get him to check current draw and voltage drops on the charge output side, and earths again.
So today i dropped it over to him to work his magic, basically the outcome has been that he has rewired the output side of the alternator and it is now charging much higher, right where it should be. Earths were spot on. I havnt road tested it to see if the misfire has gone yet but hopes are high. It does make sense though the way this problem manifested itself, as it was fine when it first went on the road and gradually got worse... Much like how a few bad connections could slowly get worse...
PostPosted: Wed Oct 02, 2013 12:08 pm
Updates without pics should be illegal haha. :P
Still got those remote shifters?
PostPosted: Fri Oct 04, 2013 1:36 pm
Yeah I do mate. I'll try & throw some pics of the car up tonight :)
Ps yeah I'm calling this misfire FIXED
PostPosted: Sat Nov 30, 2013 6:38 pm
Misfire fixed..........when are we going to see the boost turned up Coxy?
G180 252Rwkw on 26psi with GT3082
126Mph on pump fuel
PostPosted: Thu Dec 05, 2013 7:01 am
Not fixed... Lol... Runs so much better everywhere else though. I'll do a proper update on this thread soon.
PostPosted: Mon Jul 13, 2015 1:35 pm
Dave been a long time since update
Any progress? Misfire issue sorted?
Which plugs were / are you running?
