It is currently Tue Jun 25, 2019 6:05 am
Post new topic Reply to topic  [ 9 posts ]
 Post subject: 253 Wagon Engine conversion
PostPosted: Sat Jun 08, 2019 5:56 pm
This is just a quick build thread on fitting a 253 into a late model wagon. Nothing special, just need to document it.
Car and motor
Moving the boat anchor from house to shed.. no mean feat over dirt n grass
Quick scale weigh to know how much the springs will hurt
Prefit
getting close to optimal location
A few goodies
gotta get a converter as it didnt come with one
OoOoOh pretty
Put a hole in the bonnet and can do a powerskid!
 Post subject: Re: 253 Wagon Engine conversion
PostPosted: Mon Jun 10, 2019 5:56 pm
Ok!
More work on placement, its right where i'm happy with it sitting.
Steering rack will have to be lowered about 20mm
Used the factory gemini gearbox mount and lined it up with factory holes
Might sit a smidgeon higher that where it is placed now, but its in the middle, and in best position. I will have to trim and reinforce the passenger side webbing.
So far this is the only spot i can find that doesnt have enough clearance
OoOoOh pretty
PostPosted: Mon Jun 10, 2019 6:41 pm
What happened to 1uz
75 TX Coupe.
https://racemagazine.com.au/
#TurboFamily
PostPosted: Mon Jun 10, 2019 6:58 pm
Still in the works, im 200cc over for an early model so awaiting more info on special permissions
OoOoOh pretty
PostPosted: Mon Jun 10, 2019 10:57 pm
Oooh man :(
75 TX Coupe.
#TurboFamily
PostPosted: Wed Jun 12, 2019 7:54 pm
Doing some house painting atm, so wont have any updates for quite a few days :(
OoOoOh pretty
PostPosted: Sat Jun 22, 2019 4:51 pm
Ok, engine out ad onto stand. Removed sump and pickup and did the comparison to the gem sump.. I have to say HOLY MOLY ITS CLOSE!!!!!
One side is literally identical to the other, only difference is bolt hole spacing. You can almost bolt the gem sump straight onto the 8, 2 front sump holes line up, but rear ones are about 1/2 a hole out each!!!.. But alas, gem sump is wider on the opposite side.
Now i chopped them both, and have it sitting in place, have measured crank clearance to sump and its ok. Oil pickup needs to be extended backwards 30mm and the gemini head welded onto it.
OoOoOh pretty
PostPosted: Sun Jun 23, 2019 6:06 pm
Trial sump is in, to clear its gotta sit a little higher than i thought. Steering rack is close, like too close, so need to drop it down 10mm for me to be happy with it.
Forgot to snap pics
OoOoOh pretty
PostPosted: Mon Jun 24, 2019 12:09 pm
People have been putting old s*#t v8s into these things since forever. Have you spoken to anyone who's done the conversion? Did they do anything to lower the rack? No other viable ways around it?
75 TX Coupe.
#TurboFamily
Users browsing this forum: No registered users and 5 guests
