It is currently Mon Nov 18, 2019 11:44 pm
Post new topic Reply to topic  [ 6 posts ]
 Post subject: Late coupe 1uz
PostPosted: Sun Aug 25, 2019 12:19 pm
Coming soonish ( maybe next year ) project.
OoOoOh pretty
Put a hole in the bonnet and can do a powerskid!
 Post subject: Re: Late coupe 1uz
PostPosted: Fri Nov 01, 2019 12:05 pm
So i have fitted an EFI fuel pump and larger line ( as previously pictured ) into a gem tank, its sitting in the boot of the car and has been tested, but have a fuel leak somewhere under the car, that im guessing is holes from ray\ts who where living in the engines valley near the starter motor.
Hopefully this weekend i'll be able to get the engine running so the car ( celcior ) can be moved to a better location.
EDIT: Found out i used the wrong fuel line, tried to unscrew the correct one and it appears to be too badly corroded, or cross threaded, but will endeavor to rectify it and get this thing started!
OoOoOh pretty
PostPosted: Fri Nov 01, 2019 2:19 pm
Bin the 253 one and focus on this.
"Great idea Jonno that's what I will do"
Sick.
PostPosted: Mon Nov 04, 2019 5:10 pm
throwing this here for reference
Rover V8 Dimensions vs Lexus V8 Dimensions
The Rover V8 basic dimensions:
Length : 708 mm
Height : 707 mm
Width: 770 mm
Weight: 220Kg (minus starter & flywheel)
Power: 150 – 230BHP (ignoring the TVR 5.0 version)
Lexus V8 4.0 quad cam 32 valve V8 basic dimensions:
Length : 655 mm
Height : 610 mm
Width: 620 mm
Weight : 177Kg (minus starter & flywheel)
Power : 256BHP -305BHP
Huh! This doesn’t make sense! The Rover looks tiny in comparison but yet the figures clearly say the complete opposite.
OoOoOh pretty
PostPosted: Tue Nov 05, 2019 8:22 am
yeah the 1uz is wide as fk. The guys on PF that did the 1uz into a rodeo got 120kw outta there's and it's standard if that helps at all.
PostPosted: Wed Nov 06, 2019 9:50 am
the 1uz is narrower than the rover and it fitted well in the gem bay, was just starter motor and extractors that were the problem. The 253 is alot more of a headache to keep street legal
OoOoOh pretty
