Ozgemini Dyno Results Thread
any more details on the engine/turbo/fuel specs?arrow wrote:The car is a td coup. it was dynoed with a manuel in it. i will post more details and pics in a new thread soon.
I was happy with numbers it made on the boost level. i feed the boost in slow as it is a G200. and we all know what g200s are like with head gaskets. the start of the run is just under 4000rpm and the top is 8000rpm
Zif what a wanker lol!
Top notch work on this car,
Andy if u think the bay is nice you should see the rest!
Did a dyno yesterday,
G180, 20 or 40thou over cant remember.
pre pollution head untouched.
not ported manifolds, early tx headers to 2inch single straight muffler and resonator.
stage 3 cam aka crowcam 507
electronic turbogemini ignition module,
9.5 static advance with dizzy advance plate taken out to 12mm so total of 33.5??? advance?
and 32 36 dyno tuned with no porting there and pretty effing rich under 3k...
did 85rwhp, and around 130~ NM Torque. Still got the nikki barrel seperator in the manifold havent cut it out yet
going on the dyno again in the near future with computer controlled ignition and everything ported...
chart coming soon waiting on email.
Some of you guys have some pretty forgiving dynos when it comes to torque... I feel so cut, 130~ nm of torque seems wrong now :S
And some guy getting 87rwkw with a stockish 1.8 seems wrong also :S
AS promised above
AS promised above
Obviously a 4th gear run... Maybe you guys run a 3rd gear run thats why your torques so fat?
Re: Ozgemini Dyno Results Thread
here is a video of my Gem on the Dyno.... Huge thanks to Darren Hunter (gemracing) for the build and Tune.
Tune is a safe one 267rwkw - 27 PSI and is more than enough for its Maiden run at the track in a couple of weeks time.
set up is capable of more power but as is stands we are expecting to see mid to low 10s passes which is more than quick enough for myself as this will be my first time down the 1/4
G180
Trimatic
Transbrake
Borg Warner Spool
E85 Pump Fuel
http://www.youtube.com/watch?v=SW5mJSpO ... e=youtu.be
G180
Trimatic
Transbrake
Borg Warner Spool
E85 Pump Fuel
TG - GEMRACING G180 Turbo Drag Car
TF - GEMRACING G200 - Twin 45 Side-Drafts
You will Sh_t yourself. LOL Hold on tight.
TX Coupe. Isuzu G180, gemini auto and gemini diff. 10.84@127mph
TG Panel Van- G180
TG Panel Van- G180
No doubt, are you coming Arthur?OLDSCHOOL wrote:You will Sh_t yourself. LOL Hold on tight.
would be cool to go side by side down the strip.
Yep. Ill be coming down.
TG Panel Van- G180
TG Panel Van- G180
Dyno dynamic dyno
737.7hp at wheels
G180 spool rods g180 crank
Thomas4parts mls head gasket
Gemini trimatic
Gemini diff
More power to come
Thanks horse power solutions for the help with the tune
Proport heads
6boost
Spool imports
737.7hp at wheels
Gemini trimatic
Gemini diff
More power to come
Proport heads
6boost
Spool imports
How much boost are you screwing into that thing damo!
