I have 45mm dellorto twin carbs with 4 ram tubes on my gem 1.6L...... ppl have been telling me i need to do a port and cam job for this to work correctly...good air flow blah blah blah fuel blah blah
Is this true???? i did want it to work at the best of its ability, what would you guys recomend i do on a port and cam job????
(also have flat top 1mm oversize pistons, 4:1 extractors, 2.5 inch exhaust) if dat helps??????
cheer Robb
PORT AND CAM JOB .... advice recomendation
- Chatterbox
- LOK15
ditch the 45's and get 40's , no need for porting or cam with the slightly smaller carbs , and you'll still get optimum performance , good torque and a bit better economy.
BUT , if you want to spend the coin.. get a monster port job , and a 35/75 cam , them it will get up and boogie , oh and regraph the dizzy if you dont have a vacuum advance setup on the carbs.This will help grab a tad more power
LOK15 wrote:ditch the 45's and get 40's , no need for porting or cam with the slightly smaller carbs , and you'll still get optimum performance , good torque and a bit better economy.
BUT , if you want to spend the coin.. get a monster port job , and a 35/75 cam , then it will get up and boogie , oh and regraph the dizzy if you dont have a vacuum advance setup on the carbs.This will help grab a tad more power
Wish my gem would boogie
