OzGemini Top 10 Dyno Results Listing
General Gemini Chat
79geminifast
Re: OzGemini Top 10 Dyno Results Listing
Post by 79geminifast »
Nice setup man. Not taking anything away from the power output, however if I may ask, you sure on the 30psi? If that's correct, then you gained 40hp atw from 13 more psi of boost, or 3.3hp per psi. Something doesn't seem right there as once you start getting such returns, it's indicative of an exhaust backpressure restriction, inlet restriction or something else that's just askew.
I know you went from a gt35 to a gt30, so assuming you were chasing spool here. Maybe you downsized rear housing in the process, and now hit a restriction? In saying that, even a gt30 60mm wheel with a 0.63 would still be good for 30psi on a 2litre though.
Would be great to hear your input on this.
Mick[/quote]
Sorry since the dyno its had the head and inlet manifold opened right up and cam done so im yet to get it tuned with those done.
The cam that was ordered was completely different to what was ordered (tighe 1354c) it was no where near the specs that it was dialed in for. Dialed in off their spec sheet but unfortunately they didnt grind it to their specs lol. Hence why i got surecam to regrind it. This is 2nd cam from tighe that has been completely wrong main reason it was not making the power and the inlet restriction but both fixed now. Was also having problems with crankcase pressure so have i have added a extra breather and baffled catch can. It should be a completely different car when its tuned again. Had a issue with eboost2 as well so that was an issue that just needed to recalibrate it.
Hopefully back on the dyno in mid january
Your fingers are there to be Burnt.
DR_GEM
Post by DR_GEM »
That would make sense then :)
Should be ripper setup once retuned good luck with it
moley
Post by moley »
I will be interested to see how it goes as well
Power variation seems all over the map with g series builds!
archangel62
Post by archangel62 »
Bit late but my 350rwhp in the 4ZE1 was on about 24psi. The exact boost varies a little during the run of course.
doolow
Post by doolow »
what about a n/a rotary tg with 250 rwhp :P
If it ain't making dollars . it don't make cents .
doolow wrote:what about a n/a rotary tg with 250 rwhp :P
what;s it run bro. It can slide in there.
doolow
Post by doolow »
Jonno wrote: Mon Nov 04, 2019 1:00 pm
13b with a awesome driver ask footner!!
