It is currently Wed Sep 23, 2020 5:42 pm
Post new topic Reply to topic  [ 11 posts ]
 Post subject: rockers and shafts
PostPosted: Thu Sep 14, 2017 12:29 pm
Hi lads and ladies
What's everyone do with rockers and shafts when getting heads rebuilt?
I have a few sets here and all look s#@t, can they be brought new still?
Is there a wear limit on them? How are they measured?
What are my options, seems backwards to put new valves and guides in a head then strap some old s%*tty looking rockers and shafts to it
 Post subject: Re: rockers and shafts
PostPosted: Fri Sep 15, 2017 7:25 am
Mix and match really; new ones dont exist as far as im aware. You are basically looking for a set of shafts that arent too worn. Rockers you can clean up the pad where it contacts the cam but i suspect there shouldnt be too much wear in that area anyway. Any wear gets taken out by valve adjustment.
93 200TDI Discovery
PostPosted: Fri Sep 15, 2017 11:15 am
Mix and match is what I have started to do.
I have a good set of shafts. but the contact face for the rockers have been messed with and only half the face makes contact.
I have a few different sets of rockers to pick through to find a set that are good. And most are OK as it looks like its the shaft the wears not so much the rockers.
So quick linish of the shafts in the lathe and the best of the worst rockers it is.
I can find new alloy 4z rockers and and a few steel g series ones but no shafts that I can confirm will fit
PostPosted: Fri Sep 15, 2017 12:47 pm
These look like the right rockers https://www.ebay.com/p/Engine-Rocker-Arm-Sealed-Power-R-901/175089636?iid=371739497870&_trkparms=gclientid%3DsIVfVhkwmVJ40T7mBCK8vSWtjyOX6d0nsl8EYQKXwas-03oMosfbKo_6FoDKZRn3&_trksid=p2489528.m4335.l8630
And these are the 4ze1 alloy oneshttps://m.ebay.com/itm/Engine-Rocker-Arm-SEALED-POWER-R-1016/382197860499?epid=76336356&fits=Make%3AIsuzu%7CModel%3ATrooper&hash=item58fcc48893%3Ag%3ACrcAAOSwRLlZoK23&_trkparms=gclientid%3DCLIENT_ID(ebay)&_trksid=p2489528.m4335.l8656
PostPosted: Fri Sep 15, 2017 1:29 pm
You can also get then for Rock auto (both rockers and shafts). Go for the steel rockers if you an get them
http://www.rockauto.com/en/catalog/isuz ... r+arm,5656
$US3.65 each plus hefty post
PostPosted: Fri Sep 15, 2017 4:13 pm
Rockers are only $60 aud to the door.
Its the shafts that costly
PostPosted: Mon Sep 18, 2017 7:34 am
Guess it depends on how bad the ones you have are, and wether or not its worth getting new ones.
Toby, whats the go with ordering from rockauto? Got a few things i need to source from there....just have no idea how to go about it
93 200TDI Discovery
PostPosted: Mon Sep 18, 2017 8:09 am
Yeah I'm still unsure on if to replace them or not.
As for rock auto. I haven't ordered anything but seems like most add to cart then go through check out process
PostPosted: Mon Sep 18, 2017 12:32 pm
Rockauto are the same as most sites for buy on line. They are set up for international orders.
The only thing you need to be watchful of is that if you order stuff from multiple stock warehouses the international post cost jump up. In the check out the warehouse sources will be marked "A", "B" "C". On the check out it will tell you if there is extra postage for multiple sites. if you are buying a single line of items, engine, brakes, suspension, etc they are usually from one warehouse and not a problem.
The customer service is really good. If there is a problem they fix it .
PostPosted: Tue Sep 19, 2017 7:33 am
Ill give it a shot, ta. Need to get my hands on the DOHC cam bearings.
93 200TDI Discovery
PostPosted: Fri Oct 27, 2017 7:29 pm
If you want to run swivel feet you need steel rocker arms and they need to be modified. That's for a g series though. Usually we just feel the wear between the shaft and rocker arm, it's very obvious if they are worn you will see it on the shafts and can measure the amount of wear between where the arms run and where they don't.
http://www.ozgemini.com/forums/non-tech ... hp?t=44564
Users browsing this forum: No registered users and 14 guests
