It is currently Sun Sep 20, 2020 3:08 pm
Post new topic Reply to topic  [ 2 posts ]
 Post subject: Help!!! No sound
PostPosted: Thu Apr 10, 2014 8:23 pm
So I've been installing my stereo into my gemini I have a pioneer head unit 2 channel amp and a single channel amp I have power to the amps and have the Rca's connected and speakers connected but when I go to play music to test it I get nothing??? Any ideas what it could be it's all brand new
 Post subject: Re: Help!!! No sound
PostPosted: Fri Apr 11, 2014 6:22 pm
1.When it is turned on and playing music just pull the rca's out and switch them around, could be something as simple as the rca's in the output terminals instead of input
2.Check the rca's connection to the headunit is tight, also try the different methods of connection ( AUX, USB, Bluetooth )
3.Also check that the +, - wires to each of the drivers and amp have a thorough connection
If you are 100% sure the amp(s) has power and none of these things are causing the issue then i would look at the headunit being faulty
Corey
TC g161z turbo daily
Adaptronic e420d, proboost gt2871
TG g161z drift car.
- G161z 1643cc, twin 40 dcoe webers.
14.994 @ 89.96/91.41mph
115.2whp @ only 6200rpm
