It is currently Mon Jan 25, 2021 9:09 pm
Post new topic Reply to topic  [ 8 posts ]
 Post subject: how to make a door pin remover
PostPosted: Thu Oct 13, 2005 5:11 pm
firstly toddle off to supercheap........
buy a $3.95 battery hold down bracket
you need to make sure it has a thin rod and metric/small thread
you'll also need a 10mm nut , and a 12mm nut ( a welder is also handy)
ok , now you can see the 10mm nut has been ground down , use a grinder , or a bench grinder for the task (make sure you keep it rounded)
It should be the same size as the pin for maximum effectiveness
Now weld on the 12mm nut down towards the bottom of the rod (as per pic) if you dont have a welder , stop into a welding shop and ask them if they can quickly throw a weld on it , shouldnt cost you anything for them to do it
and if you had the original pin removing tool you can still use the steel bar used to hold the original pin while you belted it with a knockometer (hammer) If you dont have this tool , get a 12mm metal rod with a 7mm hole drilled in the end to go on the pin remover.
im on my 2nd one , the first one outlasting my original $40 tool by about 40 doors
PostPosted: Thu Oct 13, 2005 7:47 pm
Excuse my ignorance, but how the hell do you use it? where does it go? what do you hit?
PostPosted: Thu Oct 13, 2005 10:11 pm
gemini doors are held on with pins , like a commodore , you put the shank thu the centre of the door pin and screw the rounded nut on , then you get your 12mm bar with notch on the end , and belt it with a hammer , this takes the pin out from the hinge
PostPosted: Thu Oct 13, 2005 10:27 pm
Yea, i think i get it now, i'll have to go make one and give it a go.
PostPosted: Sun Oct 16, 2005 10:17 am
Or you can just buy one from your local paint & panel supplies.
R.I.P. LCD-754 MSJ-142 AEQ-83P AMO-07T CUTLOW
PostPosted: Sun Oct 16, 2005 11:33 pm
i bought a set from autobarn for $10... much easier :P
ʎɐqǝ uo pɹɐoqʎǝʞ ɐ ʎnq ı ǝɯıʇ ʇsɐן ǝɥʇ sı sıɥʇ
PostPosted: Fri Sep 15, 2006 12:17 am
yeah its nice to do things yourself...but for $10...its hardly worth it
 Post subject: Re: how to make a door pin remover
PostPosted: Sun Apr 03, 2016 7:54 pm
If you don't get the 12mm welded on, use a vice grips and attach it to the rod.. Hit down for the top pin, up for the bottom.. have someone hold the door.. makes things easier.
You'll also have to drill out the ( can't remember what its called ) small length of metal from the body to the door.
Users browsing this forum: No registered users and 4 guests
