gemini increased steering angle
Gemi Coupe
Post by Gemi Coupe »
post contents removed
tezza
Post by tezza »
Quick racks are available in the UK for vauxhall chevettes. You can contact this website to see if they will fit a Gemini.
http://www.tjmotorsport.co.uk/
Drive fast..Take risks!
Gene FJ20DEBT
Post by Gene FJ20DEBT »
tezza wrote:Quick racks are available in the UK for vauxhall chevettes. You can contact this website to see if they will fit a Gemini.
i cant seem to find them anywhere tezza? what section are they found under?
F|sh
Post by F|sh »
Gemi Coupe wrote:
F|sh wrote: Increasing the front track increase oversteer.
thats EXACTLY why a drifter would want to do it, its cheaper than having an engine that is capable of making power, a diff that is set up properly, and the ability to drive properly.
And yea gene, your forgetting about the rear mount of the lower control arm in the chassis (so did i :oops: ) but that means that my idea is better :P :P
WE increased the front track to give better front end grip.
I have done the front lower control arm mod. i have 3 degree's. :)
Tezza cheeers for the link
zep
Post by zep »
I don't know if TMJ do them anymore. I did, however, read an article the other day on fitting an Escort quick rack (2 rotations to lock) to a Chevette, seemed easy enough. Tried to find it again tho and couldnt.
tezza
Post by tezza »
If you go to www.chevettes.com forum for parts for sale/wanted there is an article on the first page. The guy is taking orders for quick racks but needs numbers before getting them made.
Rodeobob
Post by Rodeobob »
F|sh wrote:Why would a drifter need more lock? .
The more fully sic sideways the more points.
The sharper your steering angle the more sideways you can get an the more fully sic you have the potential to be.
I say this thread is way off point.
Increasing track and a quicker rack wont help your steering angle become sharper.
Butchering up your suspension will do that till the rack runs out of throw.
Bob.
archangel62
Post by archangel62 »
I know I'm digging up an old thread. Just wanted to say - if there are any mods watching - reckon this could get moved to tech discussion or the suspension section? I was thinking of starting a new topic til I did a search, but it'd be easier if it was there :wink:. Lots of great info here too.
Gemi Coupe
archangel62
Gemi Coupe wrote: Image
That's just.. Wow.
How readily available, and how expensive are high tensile adjustable bolts and bits like that? If I could get my hands on the right bits and pieces, I know a few welders, and I think a setup using at least some parts of that (like the upper "control arm" for instance) wouldn't really be that hard.
And of course the temptation to fit coilovers to a whole new lower control arm setup and do away with the bumpstops cops love to hate so much has been nagging at every Gemini nut's mind...
Oh and thanks Gemi Coupe for moving thread :D
MAT713
Post by MAT713 »
i cant see any really need to completely re-engineer the wheel if there is a fairly simple solution at hand.
drifters have simply extended their racks and run longer tie rod ends to get more lock. its been tried tested and proven to work time and time again. saying that, its yet to see if proven effective on a gemini. the above formula is normally applied to the nissan drift cars.
AE86's just use the shorter steering arms from the models that came with power steering, obviously leaving the non power steering rack in place.
having huge amounts of steering lock is crucial for a drift car to be COMPETITIVE. thats the difference, any gem with standard lock will go fairly good, with the appropriate driver. how ever in a comp. where your being judged against another car, its so crucial to have more speed and more angle, hecne the lock required
= FOR SALE = Mazda RX-7 S6 13b TWIN TURBO set up - VGC, Low KM's, Everything Included
= FOR SALE = Mazda RX-7 S6 FRONT X-MEMBER - Including Upper / Lower Control Arms & Hubs
Extending your rack isnt the be-all-end-all sollution.
Think about it. Your stub axle pivots in the middle, with [in the case of the gemini] the rack on the forward edge. By extending the rack ends, you push the wheels out, and you end up with [excuse the crude drawing] wheels looking like this.
| |--------| | to this / / ------- \ \
To correct the alignment the pivot point would have to be moved forward. This is where the problems begin in a Gemini.
Then theres things like tyre and wheel clearance...
Nick-
MAT713
Post by MAT713 »
wheel cleareance is always an issue, hence y most ofthe guys run wheels with +35 or less on nissans,and the toyotas go for +10 or less
Gemi Coupe
MAT713
Post by MAT713 »
umm, if you have a good look over any top level drift car in Australia, you will actually find they are very well thought out pieces of engineering, taking only minor set up adjustments to set them up for grip racing.
the common belief is that the drift cars are set up to slide, or promote oversteer. this is very far from the truth, higher skilled drivers are always constantly trying to find more 'grip' in the car which in turn gives more speed while sliding. the cars are always well balanced, and even the tracks are very neutral. if you build a car designed to promote oversteer in the general world of grip racing, you will find u have just built a slow and unpridictable car to slide
excessive camber isnt really that common place anymore, only the punters going for the wannabe 'look' will dial in 5 deg - camber.
most of the guys at the top, run -3 up front and never any more then -1 on the rear. saying all that, its wat said here this is works for silvias and the like, not really been tried and tested on a gem to know my knowledge
