EOI: Custom Gemini diff conversion R&D and manufacture
boostdgem
Post by boostdgem »
for what its worth I would be keen if all the original objectives were met, great idea............but it looks like it has died off??????
G180 252Rwkw on 26psi with GT3082
126Mph on pump fuel
Cuz
Post by Cuz »
hey, yeah they are really busy atm and I have not spoken to them in about a month. will give them a call this week sometime.
PSIGEM
Post by PSIGEM »
Yea keen for a update, Ive got some minispools on Order but if this is going to go ahead Ill cancel them.... just hope I find out before its too late
I love old cheeseburgers ...
eskylid
Post by eskylid »
updates?
Pricey
Post by Pricey »
Can you fellas give us a link where I could find info on the construction of diffs. I've got no idea what your talking about, but I'm a student engineer, might be able to be useful down the track or something.
Gene FJ20DEBT
Post by Gene FJ20DEBT »
Pricey wrote:Can you fellas give us a link where I could find info on the construction of diffs. I've got no idea what your talking about, but I'm a student engineer, might be able to be useful down the track or something.
google
Cuz
Post by Cuz »
Ok, trying to get this resurrected.
Maybe having some other forum members call up and ask about it will give him a push in the right direction. If you are keen:
Bosnjak Engineering
Ph: 02 9757 2133
Ask for David
There was 16 that expressed interest so even if 1/4 of that can call then it would be a good thing I reckon.
DR_GEM
Post by DR_GEM »
will call tomorrow and report findings
Cuz
Post by Cuz »
Germinator
Post by Germinator »
You blokes seem to be willing to spend massive amounts to have custom 31 spline axles made.
I have some questions to ask...
When it comes to rear end failures, what power are you putting through the standard Gemini rear end, and what parts are failing? I don't think I've yet read a single post where the 'weak' 23 spline axle has been the part failed. Differential gears seem to be the breaking point according to what I have read.
Now the difference in strength between a 23 spline, 25 spline and 28 spline axle is phenomenal. If people are not breaking 23 spline axles the odds of breaking a 28 spline is really slim. Remember you are putting it into a 1000kg car so it's copping less stress than it would in the substantially heavier car it was designed to be used in.
Do you really need to go to the expense of custom making 31 spline axles? A couple of other points to consider with the bigger axles are, heavier sprung weight and bigger axle means more space needed to accommodate it in the diff centre. What diff centres are you using that have 31 spline axles to begin with?
Cuz
Post by Cuz »
most I ever planned for was 28 spline
Gene FJ20DEBT
Germinator wrote:You blokes seem to be willing to spend massive amounts to have custom 31 spline axles made.
the stock axels twist the spline of all the time with decent power
cdtpf60
Post by cdtpf60 »
i may be interested depending on cost i dont need rear disc's (groupc wont let me use them)but a deacent lsd in a stock type houseing sound good as we're not allowed to change rear end mounting points so no hilux or 9" for me.
happiness is a cdt pf60 race car
now being worked on!!!!!!!
Germinator
I remember the time of big heavy cars like the HT 350 GTS Monaro's (180Kw/515Nm) where you had 1400kg of metal being looked after by a 3.36:1 or 3.08:1 ratio 10 bolt Chevy "Positraction" LSD diff. They used 28 spline axles and they didn't break. Same with the GTHO Falcons. Heavier still with an even more torquey engine they used 28 spline axles except in the XY model which used 31 splines. All the rest were 28 spline. I can tell you now, You'd be hard pressed to twist or snap a 28 spline Ford axle unless you were absolutely abusing it and I mean to the point you shouldn't be driving. I think you'll be wasting your money stuffing about getting 31 spline axles made. It's an overkill for such a light weight car as a Gemini. What diffs are you planning on using that have 31 spline centres anyway?
MGOTD
Post by MGOTD »
this threads is for custom made lsd centers that will fit directly into the petrol gem housing, they are basing it off of skyline lsd centers i believe hence the 31 spline.
Matt
