another possible lsd option
BAD 44u
Post by BAD 44u »
PSIGEM
Post by PSIGEM »
Do they use a Borgy or Salisbury diff in kadetts?
I love old cheeseburgers ...
redzone (coxy)
Post by redzone (coxy) »
they use an opel diff..
BAD 44u
Post by BAD 44u »
whats the difference in the opel diff.
looking at risse motorsport website the opel kadett c runs a torque tube style diff looks very similiar
gemsince88
Post by gemsince88 »
I read somewhere that the Opel centres were interchangeable with the twin cam Piazza/Impulse centres and therefore a diesel centre.
elky
Post by elky »
lol, a diesel diff looks like a petrol one and NONE of the internal bits interchange....so going on that (and having examined a opel diff from pics) i would say no go.....i could be wrong but until some1 gets a opel diff to compare we are none the wiser....
gemsince88
Quaife in the UK make torsen style centres for the opels and piazza. Note the label in the bottom right corner. I have used this diagram and compared it to the diesel centre I have and everything lines up. So from this information you would conclude that an opel manta and some kadett centres would fit a diesel housing. It would still need someone to fit one and prove it though.
http://www.quaife.co.uk/sites/default/f ... /QDF4B.pdf
GEMWRC
Post by GEMWRC »
Did they have TwinCam Piazzas in the UK , maybe one of our English PIazza Freinds can help
gemsince88
From what I can tell, like Australia, the UK only got the turbo Piazza. Like Australia some of the non-turbo cars snuck in. The diff behind the non-turbo cars is a torque tube style and shares the centre with opels and diesel gemini where as the turbo Piazza has a bigger banjo style diff. A non-turbo Piazza can have a twin cam, G200Z or 2.3l SOHC. The US on the other hand got everything but they called it Isuzu Impulse.
BAD 44u
Post by BAD 44u »
so my next question will a petrol diff full spool fit the diesel housing
gemsince88
No. Not easily anyway. The carrier in a petrol salisbury diff is longer than the diesel carrier. The early Borg Warner comes close but is too small. If I could find my diesel centre I would post some pics but I think its buried under some Ford crap.
GEMWRC
Post by GEMWRC »
I thort you measured it all up compared to you diesel centre.
gemsince88
That was six months ago!
gemsince88
Here is some pics for you.
Like I said, buried under Ford crap.
Left to right : Diesel, BorgWarner, Small salisbury limited slip
Diesel next to salisbury
Just one measurement to compare
Diesel crown wheel spigot diameter. 110mm same as quaife diagram
BAD 44u
Post by BAD 44u »
awesome info. are the crown wheel and pinions interchangable.
